Towing upwards of 15,00lbs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 9 replies and been viewed 1442 times.
post #1 of 10 (permalink) Old 04-26-2011, 10:02 PM Thread Starter
BlowinSmoke's Avatar
Pushing the towing capacity towards 15,000lbs in the 02 2500 is it possible and how?
Dodge .com shows axle gearing 3.55 at 9,300lbs and 4.10 at 11,300lbs.
BlowinSmoke is offline
post #2 of 10 (permalink) Old 04-27-2011, 02:03 AM
bmoeller's Avatar
Well, you should've started with a 3500 to begin with. Better safety factor if a tire blows with a heavy load. Friend of mine grosses 30k+ with his W250 4x4 on a regular basis.
These trucks can handle more than they are rated for.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 10 (permalink) Old 04-27-2011, 03:23 AM
ADMIN/MAFIA
neeltburn's Avatar
Stopping is also a big concern. Make sure you have trailer brakes in working order! Sometimes its better to make a couple trips at a lighter weight and have control over your load than overload the truck and break it or worse have an accident that could have been avoidable.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
Johnp3 (04-27-2011)
post #4 of 10 (permalink) Old 04-27-2011, 04:05 AM Thread Starter
The 3500 is coming. Right now we only have a small horse trailer and two horses. Just wondering and wanting to pull as much hay as we can instead of multiple weekend trips with her parents truck now that we've got this truck.
post #5 of 10 (permalink) Old 04-27-2011, 06:12 AM
hayjayhorses's Avatar
15,000 is no problem for this truck, I have hauled 10-12 ton loads of hay with single wheel trucks, many times with no issues.
as for brakes on your '02 Dodge, you can put 30mm wheel cylinders from a 1 ton GM. Dodge uses 27mm wheel cylinders.
I run electric over hydraulic disk brakes on my 40' flatbed trailers they work awsome.
If your truck has a Slush-O-Matic, be sure to let it cool down before you shut it down.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #6 of 10 (permalink) Old 04-27-2011, 01:01 PM Thread Starter
Slush o matic would be what? An automatic trans?
If your talking about your signature truck it looks like it can handle 10-12 ton loads
post #7 of 10 (permalink) Old 04-27-2011, 01:46 PM
yes
no, I have '94 SRW F350. I had a '05 SRW Ram 3500.
The signature truck is my custom built hauler '97 GMC topKick, 12 v P-pumped cummins 5.9, Road Ranger 13 speed, 3.36 rear end with a locker.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #8 of 10 (permalink) Old 04-27-2011, 02:14 PM Thread Starter
The truck we'll be using Jays the 2500. Thats why moeller said shouldve gone with the 3500.
post #9 of 10 (permalink) Old 04-27-2011, 03:55 PM
a dually is more stable, especially in the cross winds. The single will be fine as long as it is a gooseneck. you really need a dually for a bumper pull.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #10 of 10 (permalink) Old 04-27-2011, 06:21 PM Thread Starter
Yeah dually would be preferred. Right now the 02 only has the rear hitch. Wouldnt mind throwing a gooseneck on her.
Towing help!!!! ehopp88ss 5.9L Cummins (2003-2007.5) 12 08-11-2010 09:42 PM
Anyone towing with it yet? WasGas 2011+ 6.7L Power Stroke Diesel 3 08-09-2010 10:55 PM
6.4 Towing with 37s Bad Brad 2008-2010 6.4L Power Stroke 2 07-11-2007 03:59 AM
SCT Towing 15k!!! ACC inc. General Ford Truck and Excursion 9 04-07-2006 04:10 AM
Towing with TS 5X Dieselman 2003-2007 6.0L Power Stroke 22 03-15-2006 05:37 PM
