Turbo Timers - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 7 replies and been viewed 1354 times.
post #1 of 8 (permalink) Old 04-27-2011, 01:08 PM Thread Starter
BlowinSmoke's Avatar
Turbo Timers
Anybody have one and do they work great? What brand are you running?
BlowinSmoke is offline
post #2 of 8 (permalink) Old 04-27-2011, 05:28 PM
I installed a remote starter on mine, that has 2 different key-off run times. Pit-stop is programable between 15-20-30 minutes, while the Turbo cool down is only 3 minutes. My fob has two different key-off buttons, one for pit-stop, and one for cool down. I will look at the brand/model number when I get home later.
03 3500HD 6x6 starting the add ons.
HAD'01 Ram 2500 SLT Laramie 4x1of2, 24v CTD, electric blue on silver 2-tone, matching blue spray-in bed liner, leveling spacers in front end, 3:55's, 'pork chop' tool boxes and tailgate box, back up/ work lights under rear bumper, On-board air, Roof mounted Air horns, Gauges in Pillar include Fuel PSI (pre & post filter), Oil PSI, Boost/EGT, Engine temp/Trans temp. BHAF, Edge EZ
Firestorm is offline
post #3 of 8 (permalink) Old 04-27-2011, 06:23 PM Thread Starter
Interesting. I saw some from Greddy and HKS that would let you lock and shut the truck then it would turn off between 1 and 3 minutes
post #4 of 8 (permalink) Old 04-27-2011, 06:43 PM
They use to be real popular in class eights, Unless you pull heavy loads, and live at the top of a hill and pull hard all the way they are not necessary anymore. If you slow down before a stop and get out and do a walk around your truck before you shut it off you do not need to have one.
Johnp3 is offline
post #5 of 8 (permalink) Old 04-27-2011, 06:48 PM Thread Starter
I usually just sit and chat in the truck before I get out or play with the radio. So far everything stays pretty cool.
post #6 of 8 (permalink) Old 05-09-2011, 09:14 PM
tbroadus_41's Avatar
Waste of money if your putting it on a standard trans truck. Who wants to leave their truck parked in neutral with the park brake on all the time?
tbroadus_41 is offline
post #7 of 8 (permalink) Old 05-10-2011, 03:42 AM Thread Starter
Hows it a waste of money? I dont know anyone that puts their truck in neutral and sits on the brake alot.
post #8 of 8 (permalink) Old 05-12-2011, 08:35 PM
Its a waste because if your just going to sit in your truck till it cools off you don't need one. If you dont sit in your truck like your late for work or something and jump out you can't just leave it in gear while it idles to cool down, thus the leaving the truck in neutral while your not around it. I have a timer on the edge box that i have but i never use it because im not going to walk away from my truck knowing the only thing keeping it there is the park brake.
Turbo timers 4x4freak 2003-2007 6.0L Power Stroke 12 01-05-2009 10:05 PM
question on turbo timers imported_fuzzy 6.7L Cummins (2007.5-2011) 5 03-24-2008 11:52 PM
Remote start/turbo timers USAFdieselman General Ford Truck and Excursion 12 07-30-2007 04:42 PM
Turbo Timers imported_BigPSD General Ford Truck and Excursion 7 12-12-2006 05:56 PM
turbo timers haz-mat19 Supporting Vendors Forum 1 08-26-2006 01:54 PM
