new build start up.... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 2 replies and been viewed 709 times.
post #1 of 3 (permalink) Old 05-11-2011, 02:39 AM Thread Starter
IDImonsterstack's Avatar
ok got my motor built and having a issue starting it. the timing is correct checked it 3 times have been cranking it over for awhile and cracking injector lines and what not i got it to fire up for about 5 seconds running and shaking on about 3 clyinders after that nothing but black and blue smoke while cranking it over and wont start up agian.....more air in the lines??
under the knife for rebuild
IDImonsterstack is offline
post #2 of 3 (permalink) Old 05-12-2011, 04:04 AM Thread Starter
ok after another failed atempt at starting the truck i put a little gas on a rag and put it over the intake it started and it stays runningit has a steady miss to it do im thinkin there is probley alot more air in the lines
post #3 of 3 (permalink) Old 05-15-2011, 01:37 PM
You may need to check the pump key on the injection pump, they can get bent.
later is offline
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 09:00 PM
Fresh Start: needing advice to start off on the right foot. MoparChallenger 5.9L Cummins (2003-2007.5) 22 03-07-2008 01:10 AM
Is this a good start to a build? 284 5.9L Cummins (Pre 1994) 4 02-27-2008 12:22 AM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 11:55 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 07:32 AM
