tuner advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by coreyk, this thread has received 8 replies and been viewed 21624 times.
post #1 of 9 (permalink) Old 05-19-2011, 12:41 PM Thread Starter
tuner advice
I have a 01 cummins, i am using the quadzilla adrenaline right now and im not happy with it. I am planning on doing the "super b" turbo, 150hp injectors and i have a intake and 4" exhaust right now. when i do the turbo and bigger injectors what tuner do you think would be best? Thanks in advance
coreyk is offline
post #2 of 9 (permalink) Old 05-19-2011, 08:09 PM
dodgedevildog08's Avatar
Tuner Suggestion
I would suggest the Smarty Tuners. They allow you more function then just picking a power level. In this case it would be the Smarty S-03 for your truck. It is the same tuner I have for mine and I Love it. I will say the only downfall is there is no way to shift on the fly and you dont get gauges out of it like you would with an EDGE tuner, (but really you should put gauges on your truck. boost,egt,transtemp, and I highly suggest fuel pressure so you dont run your VP44 dry using the stock lift pump). You have to pick your settings and flash your ecu before you start the truck and take off down the road. As soon as you get it you can hook it up to your computer and download the REVO software. I will say this I average 22mpg on the fuel saver setting.
Here is the weblink and I pasted the details about REVO below that.
http://www.madselectronics.com/Smarty03.html
Smarty S03
Today, this becomes reality!
When you enter the “ECM update“ menu on Smarty you will find a newly added chapter:
"Adjust Options“.
Once entered, this menu allows you to choose among several items and levels of customization.
The items are :
Speed-limiter
Torque Management levels
Injection timing
Injection duration
The levels are :
Speed-limiter
From 25 to 250 mph in one mile increments
Torque Management
# 0 - Default
# 1 - Stock
# 2 - Mild
# 3
# 4 Moderate
# 5
# 6 - Wild ( aftermarket clutch / AT Transmission recommended )
Injection Timing
# 0 - Default
# 1 - Stock
# 2 - for stock injectors
# 3 - for aftermarket Injectors
# 4 - for fuel economy
Injection duration
# 0 - Default
# 1 - Stock
# 2 - Mild
# 3
# 4
# 5 - Long
The above descriptions are for the REVO standard software.
2001 Dodge Ram 2500 / 4x4 / Crewcab / 47RE auto trans / Smarty S-03 programmer / Airdog 150
dodgedevildog08 is offline
post #3 of 9 (permalink) Old 05-20-2011, 02:53 AM
ADMIN/MAFIA
neeltburn's Avatar
My first and foremost advice would be to get a fuel system of some sort be it FASS or Pureflow AirDog with a good quality fuel pressure gauge. When I had my 01 24V I lost a Lift pump and VP within 2 months of ownership..
Once you get a good fuel system that will maintain what the VP needs stock then start planning for horsepower.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 9 (permalink) Old 05-20-2011, 12:05 PM Thread Starter
The guy who i bought the truck from said it had a "monster" vp44 pump. Any advice about those? Are you talking about upgrading my injection or lift pump?
coreyk is offline
post #5 of 9 (permalink) Old 05-22-2011, 01:45 AM
he is talking about your lift pump. the monster pump is a waste of your time. I like the edge comp hot aka edge drag comp. blows the smarty out of the water. also get a full set of gauges pyro boost and fuel pressure if auto get a trans temp gauge. stay away from glow shift.
01quadcab is offline
post #6 of 9 (permalink) Old 05-23-2011, 02:59 AM
ADMIN/MAFIA
neeltburn's Avatar
I was referring to lift pump.
The VP is very dependent on having the correct fuel pressure. Once you get the supporting mods down, IE Gauges and a good lift pump, Smarty and the Edge Comp are both good choices.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 9 (permalink) Old 05-23-2011, 12:16 PM Thread Starter
I have a guage pod now with boost, pyro, and trans temp and a seperate guage for fuel pressure. I need to get the trans, pyro and FP working. I tryed getting the fuel pressure working yesterday but for some reason i can't get it to, its a auto meter sending unit with red, black and yellow wires coming from it and i cant get a signal to the guage?
coreyk is offline
post #8 of 9 (permalink) Old 05-23-2011, 12:35 PM Thread Starter
What about the edge juice w/attitude?
coreyk is offline
post #9 of 9 (permalink) Old 05-23-2011, 03:17 PM
since you already have gauges it just costs more and is supposed to be the same tuning as a comp but to me the comp fuels harder
SCT 9625 OR tuner '08 0r '09 6.4l Delete tuner $450 shipped! 4613 Whats Been Sold 1 01-02-2010 12:08 AM
turning the SCT SF tuner into a custom tuner strokin6L 2003-2007 6.0 Tuner Forum 4 05-26-2009 03:05 PM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 10:08 PM
Need some advice... KeyserSozae 6.5L Diesel Engine 1 02-10-2008 09:09 PM
need advice for dp tuner clint1985 1994-2003 7.3L Chips & Tuners Forum 2 11-25-2007 06:31 AM
