Brakes: Replaced rear calipers, beld them, still spongy pedal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hin0031, this thread has received 5 replies and been viewed 2277 times.
post #1 of 6 (permalink) Old 05-29-2011, 01:48 PM Thread Starter
I replaced my brakes all around including the rear caliper since they were frozen and the rubber on them was gone. I bled the system and used 4 bottles of brake fluid. I now have new fluid through the system, but The pedal is very spongey and goes to the floor. It returns very slow to normal position and the abs and brake lights are on. Can't figure it out. I was told that the system has to be reset with a computer, but have no idea where to go from here. the brakes only work when pedal is to the floor and barely grabs. Any ideas?
hin0031 is offline
post #2 of 6 (permalink) Old 05-29-2011, 06:48 PM
You have to give us some information on the truck or vehicle. Year, model, make size of engine and trans type the more information you give us the easier it is to give you the exact fix.
If you pushed the calipers back without removing the brake hose you could have damaged the ABS unit. you also could have a bad brake booster, that is my first choice, for the problem.
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
hin0031 (06-03-2011)
post #3 of 6 (permalink) Old 05-29-2011, 11:28 PM Thread Starter
2002 dodge ram 2500 5.9 cummins, automatic trans. Stock.
I was told it could be that it needs to be bled with a computer? not sure.
hin0031 is offline
post #4 of 6 (permalink) Old 05-30-2011, 04:36 PM
I have never heard of a computer able to assist in bleeding. BUT I have been wrong before.
Johnp3 is offline
post #5 of 6 (permalink) Old 05-31-2011, 03:26 AM
ADMIN/MAFIA
neeltburn's Avatar
I didnt need a computer to my breaks on my 01... But I don't remember it we had to bleed the system when we replaced them.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #6 of 6 (permalink) Old 06-03-2011, 02:43 AM Thread Starter
Found it. Abs system was air logged and had to have the dealer plug into it and purdge and restet the abs computer. Thanks for the ideas and responses.
hin0031 is offline
Spongy unsafe brakes!!! Torched 1994-2003 7.3L Power Stroke 3 02-05-2012 11:48 PM
Rear Diff Replaced oldnotslow Medium and Heavy Duty 2 01-23-2011 11:54 PM
08-10 SRW Rear Brake Calipers F250/350 TooManyToys Ford Parts 0 11-17-2010 12:18 PM
rear brakes proud1 1994-2003 7.3L Power Stroke 8 10-17-2010 02:40 PM
Hard Brake Pedal but No Brakes!! Help! DINOONE 2008-2010 6.4L Power Stroke 11 07-02-2009 01:25 PM
