Wont start!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigboycuztoms, this thread has received 3 replies and been viewed 6700 times.
post #1 of 4 (permalink) Old 06-06-2011, 03:59 PM Thread Starter
BigBoyCuztoms
Cool Wont start!!!
Hello I'm trying to figure out what's wrong with my 2001 Dodge 2500 5.9 cummins HO. It is not starting at all just dead on the road one day no missing no chugging just stopped like you turned the key off and I coasted to a stop and has not started sinces then. We have tryed ether use a whole can of that and never even fired off that. I'm reading place that its the injection pump but they say it should still start and fire off the ether if it was that. Then I'm hearing that it could be the cam sensor that can make it not fire off the ether. So if someone could help me out I don't have a code reader so I don't know how to get the codes. So I need some help fast on how to find and fix this problem my truck is still not broke in yet I only have bout 75000 miles on it. I love my truck trying to get it fixed fast to get it on the road again.
bigboycuztoms is offline
post #2 of 4 (permalink) Old 06-09-2011, 09:21 PM
Turn the key to run and off 3 times and the odometer will show the codes.
hin0031 is offline
post #3 of 4 (permalink) Old 06-13-2011, 06:45 PM
layzboy2011's Avatar
All that a diesel needs to run is fuel and compression. So unless you have burnt holes in your pistons or something like that it should at least try to run on ether. Did you pull the intake *and intake heater* to spray ether? It may not work pre Turbo. However that still wont fix your problem just give you more of an idea. On these tricks the VP pump controls the timing and the pressurization of the fuel, So as long as there is fuel getting to the injection pump (did you run out? ) it is most likely the pump. But like the previous poster said, pull the codes and see what they say. If there are none related to engine things (I have a bad pump now but my codes are only for tranny things) it is most likely your vp44 and that's where I personally would start. Just my .02
01 dodge ram 2500 laramie ext. cab long box 4x4: 5" Turbo back exhaust edge with attitude
layzboy2011 is offline
post #4 of 4 (permalink) Old 06-30-2011, 12:08 AM
replace burned fuses under the hood on drivers side
call genos garage tel them whats going on, you probaby need new contacts in the starter
CLC379 is offline
7.3 Wont Start Jay21 1994-2003 7.3L Power Stroke 5 02-07-2011 05:24 PM
6.9 Wont start 8yourv8 7.3L and 6.9 IDI (Pre 1994) 3 10-08-2010 12:57 AM
help wont start again voncheese 2003-2007 6.0L Power Stroke 2 01-02-2010 03:35 AM
Wont start..? HeffPsDiesel 1994-2003 7.3L Power Stroke 15 04-20-2008 06:33 AM
