01 cummins heavy haze issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 9 replies and been viewed 1992 times.
post #1 of 10 (permalink) Old 06-15-2011, 03:37 PM Thread Starter
IDImonsterstack's Avatar
hey guys i just rebuilt my cummins it has about 1000 miles on it now im running the quadzilla adr on level 1 only im getting a heavy haze at light throttle all the way to WOT even with the chip off im getting a bad haze of blue and black. and my monitor freezes up every 15 seconds. with the chip unplugged its still doing it. any suggestions?
under the knife for rebuild
IDImonsterstack is offline
post #2 of 10 (permalink) Old 06-15-2011, 10:09 PM Thread Starter
also the truck is very sluggish off the line and even with the chip off its blowin black smoke like crazy and doesnt really go anywhere
post #3 of 10 (permalink) Old 06-15-2011, 10:18 PM
Who's injectors are you running? It sounds like the pop pressure is set too low.
later is offline
post #4 of 10 (permalink) Old 06-16-2011, 08:13 PM Thread Starter
they are just stock injectors in it right now. i checked for air leaks and i have none. right now when its idling theres no smoke but as soon as i take off its a steady light film of black smoke. for like the first 800 miles on my motor everything was burning clean then all of a sudden this started to happen and everything else looks good
post #5 of 10 (permalink) Old 06-16-2011, 11:15 PM
I guess you have checked for codes?
later is offline
post #6 of 10 (permalink) Old 06-17-2011, 12:45 AM Thread Starter
yup no codes and its gettin worse today under heavy throttle it sputters and and shoots black and white smoke a friend of mine told me injectors are goin. so ima buy some and hope that fixes the problem. im not havin any dead pedal or anything so i know the injection pump is fine and its new anyways.
post #7 of 10 (permalink) Old 06-17-2011, 12:51 PM
That would be my first guess.
later is offline
post #8 of 10 (permalink) Old 06-30-2011, 09:53 AM Thread Starter
i replaced the injectors and that cleared up the whole issue
post #9 of 10 (permalink) Old 07-05-2011, 02:39 AM
Thanks for letting us know, and glad it was a easy fix.
later is offline
The Following User Says Thank You to later For this addition to TDG:
IDImonsterstack (07-11-2011)
post #10 of 10 (permalink) Old 07-11-2011, 06:08 PM Thread Starter
no problem thats what we are all here for right lol. at first when it started doing it i was like oh no this aint good after i just spent bout 7000 rebuilding this thing. no i just got to get a new quadzilla pulse monitor casue mine is freezing up bad. and i got transmission overheating issues now and temps around town when its hot are hittin almost 200 and i got 2 coolers and fans on both.
Drove a 2010 Heavy Duty Cummins 2500 swb crew cab 4x4 Jeremiah 6.7L Cummins (2007.5-2011) 2 01-16-2010 01:26 AM
Cummins ism issue jaybirdius Medium and Heavy Duty 8 11-22-2009 02:29 AM
Why does FERD use Cummins in their heavy ones? Canyon JYD The Parking Lot 55 01-13-2008 11:14 PM
Grey Haze! Haird 5.9L Cummins 12 Valve (1994-1998.5) 5 09-28-2007 03:10 PM
06 with a white haze GOFASORGOBROK 2003-2007 6.0L Power Stroke 9 09-07-2007 12:05 AM
