FAULT CODE P0743 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by STROKER SMOKER, this thread has received 2 replies and been viewed 5033 times.
post #1 of 3 (permalink) Old 06-17-2011, 11:46 AM Thread Starter
STROKER SMOKER's Avatar
Angry FAULT CODE P0743
IVE GOT A QUICK QUESTION GUYS. i HAVE A 01 CUMMINS THAT IM HAVING A LITTLE ISSUE WITH THE LAST FEW WEEKS. UPON HEAVY EXCELLERATION AT AROUND 30 TO 40 MPH IM LOSSING POWER FOR ABOUT 1 TO 2 SECONDS RPMS DROP TO 0 THEN EVERYTHING COMES BACK AND RPM'S GO BACK UP AND TRUCK RUNS FINE. IVE GOT FAULT CODE P0743 STORED IN THE TRUCK WHEN I DUE THE CODE SCAN VIA CYCLING THE KEY. IM NOT GOIN TO LIE IM REALLY NERVOUS THE INJECTOR PUMP IS GOING OUT BUT IM HOPEING MAYBE SOME OF YOU GUYS CAN TELL ME ABOUT THIS CODE AND HAVE A DIFFERENT EXPLANATION FOR THIS. THE TRUCK HAS 149,000 MILES AND AT 80K I HAD TO PUT A INJECTOR PUMP IN IT SO IM HOPING IT ISNT HAPPENING AGAIN. IF THIS HELPS I DO HAVE A RAPTOR 150 GPH PUMP AND A FULE PRESSURE GAUGE ON THE TRUCK FUEL PRESSURE IS AT 15 POUNDS UPON FULL THROTTLE WITH TST BOX AND SMARTY TURNED ALL THE WAY UP BUT THIS ISSUE IS HAPPENING EVEN WITH TST BOX TURNED TO 0. TRUCK DOES HAVE 150 HP INJECTORS AS WELL AND A FULL BILLET ATS TRANS AND ATS 5 STAR CONVERTER. I DOUBT ANY OF THIS CHANGES ANYTHING BUT MAYBE.... ANY HELP IS REALLLYYYYYY APPRECIATED. THIS TRUCK HAS COST ME SOOOOOOOO MUCH MONEY AND I HAVE A FEELING ITS GOIN TO COST ME MORE. THANKS GUYS.
2001 DODGE RAM 2500 4X4 SHORT BOX, 7 INCH LIFT, 36'S WITH 20'S, TST BOX WITH RACE UPGRADE, SMARTY, 150HP INJECTORS, 2 CARTER 100 GPH LIFT PUMPS, ATS STAGE 5 TRANS ( FULL BILLET), ATS 5 STAR TORGUE CONVERTER, ATS CO PILOT BOX, COLD AIR INTAKE, 4 INCH EXHAUST, CUSTOM TRACTION BARS, & GEAR BOX STABALIZER BRACKET.
STROKER SMOKER is offline
post #2 of 3 (permalink) Old 06-18-2011, 12:15 AM
BlowinSmoke's Avatar
I'll check out my manuals real quick for ya.
BlowinSmoke is offline
post #3 of 3 (permalink) Old 06-18-2011, 12:33 AM
The sticky shows this, noticed it after I looked at my manual. --->
P0743 (M)
Torque Converter Clutch Solenoid/
Trans Relay Circuits
An open or shorted condition detected in the torque
converter clutch (part throttle unlock) solenoid control
circuit. Shift solenoid C electrical fault - Aisin transmission
And the diagnostics manual states this --->
P0743 Torque Converter Clutch Solenoid/Trans Relay Circuits
When monitored: Continuously with the key on
Set condition: This code will set if the voltage detected on the Torque Converter Clutch Solenoid Control circuit at the PCM is different than the expected voltage.
"Service Engine Soon" and fault code ArmyAviator Duramax 2001-2004 (LB7) 6 08-01-2009 04:17 PM
TBC Fault???? Eazydeezy 2003-2007 6.0L Power Stroke 10 05-18-2009 01:20 AM
TBC fault mbdriver 2003-2007 6.0L Power Stroke 11 11-10-2007 12:25 AM
TDC Fault? tdmr1195 2003-2007 6.0L Power Stroke 3 01-03-2007 08:09 PM
03 Dodge Fault Code INRedneck 5.9L Cummins (2003-2007.5) 2 07-31-2006 09:47 AM
