Found this under tappet cover what is it? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by LOKAN6.0, this thread has received 7 replies and been viewed 2252 times.
post #1 of 8 (permalink) Old 06-26-2011, 04:41 AM Thread Starter
I'm getting ready to do a Cummins conversion and was replacing the tappet cover gasket,when I took the cover off I found this laying in there and don't know what it is or where its from,one side looks like it broke while the other end looks like a smooth factory edge. didn't find any other pieces in there and I dont see anything in there or under the valve cover that looks anything like this.the engine is a 2001 24V. Thanks
LOKAN6.0 is offline
post #2 of 8 (permalink) Old 06-26-2011, 05:17 AM Thread Starter
Engine has 115,000 on it and Everything else so far has looked very clean,haven't found any indication of a problem/broken parts anywhere else.
LOKAN6.0 is offline
post #3 of 8 (permalink) Old 06-26-2011, 06:13 AM
Looks like a wrist pin circlip
sent from my Droid Incredible 2 using tapatalk
1998 12valve QCSB, 230HP p-pump, full cut DV's, 4k springs, dual fed by an AD 150, Industrial Injection phatshaft 66/71/14, 5x.014's, custom 2 stage water/meth injection, cryo'd 5-speed internals, 3600 SB 12 button DD clutch.
SFP12valve is offline
post #4 of 8 (permalink) Old 06-26-2011, 03:42 PM
The rocker arms are held on with a snap ring then a ring then a wavy washer. That is part of the ring.
Johnp3 is offline
post #5 of 8 (permalink) Old 06-26-2011, 04:06 PM Thread Starter
Thank you,I pulled them off a few months ago,i'll dig them out and see which one is missing pieces.
LOKAN6.0 is offline
post #6 of 8 (permalink) Old 06-27-2011, 02:28 AM
JLWelding's Avatar
Could it be off the valve stem seals?
JLWelding is offline
post #7 of 8 (permalink) Old 06-27-2011, 03:30 AM Thread Starter
I looked at the Rocker arms and didn't find anything like it at all, I'll be pulling the head off in a couple days,i'll take another good look around. I'll look into the valve stem seals,thanks for the reply.
LOKAN6.0 is offline
post #8 of 8 (permalink) Old 06-28-2011, 05:41 AM Thread Starter
It was from one of the Valve stem seals. thanks for the replys
LOKAN6.0 is offline
Tappet cover 97CumminsTurboDiesel 5.9L Cummins 12 Valve (1994-1998.5) 10 09-13-2010 04:15 PM
Tappet cover keeps on leaking 97CumminsTurboDiesel 5.9L Cummins 12 Valve (1994-1998.5) 10 01-21-2010 03:40 PM
broke a tappet!! 7inchstack 5.9L Cummins 12 Valve (1994-1998.5) 9 11-23-2009 12:48 AM
Tappet cover gasket PhilipR 5.9L Cummins 12 Valve (1994-1998.5) 3 10-05-2009 11:45 AM
AMSOIL Motor Oils, Flat Tappet and Camshaft Lobe Lubrication CrowsSynthetics General Diesel 7 01-01-2009 01:49 AM
