Efficient solvent for cleaning intercooler - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 9 replies and been viewed 16424 times.
post #1 of 10 (permalink) Old 06-30-2011, 02:46 AM Thread Starter
BlowinSmoke's Avatar
Whats a good solvent for cleaning the intercooler and associated piping of oil from prior oiled filter use?
BlowinSmoke is offline
post #2 of 10 (permalink) Old 06-30-2011, 02:58 AM
plainredtruck's Avatar
Images: 11
Simple Green works well.
Anything citrus based will clean it out as well.
Good hot water and soap do quite fine.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
The Following User Says Thank You to plainredtruck For this addition to TDG:
BlowinSmoke (06-30-2011)
post #3 of 10 (permalink) Old 06-30-2011, 03:23 AM
4cstr's Avatar
Images: 35
I agree with Ray. When I cleaned the intercooler from my 99 I poured half a bottle of simple green into it and chased it with hot water. I capped off the ends with plastic lids and duct tape and shook the bejezzus outa it. Dumped the nasty looking water out, flushed again with hot water, then let it air dry. I didn't put a fan on it because I didn't want dust blowing into it.
~Dave~
4cstr is offline
The Following User Says Thank You to 4cstr For this addition to TDG:
post #4 of 10 (permalink) Old 06-30-2011, 03:55 AM Thread Starter
Awesome. Thanks guys.
post #5 of 10 (permalink) Old 07-02-2011, 09:13 PM
bmoeller's Avatar
I use Oil Eater. Simple Green has nothing on this stuff. Non-toxic as well.
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 10 (permalink) Old 07-02-2011, 11:51 PM Thread Starter
Is cleaning the intercooler possible still in the truck?
post #7 of 10 (permalink) Old 07-03-2011, 10:49 PM Thread Starter
Got it out finally. Used what I had on hand and it did pretty good, threw in 2 bottles of la's totally awesome and capped the ends. Rinsed it twice with hot soapy water as well.
post #8 of 10 (permalink) Old 07-06-2011, 04:11 PM
When cleaning your self is not an option, a radiator shop is a quick option. also if there has ever been a turbo compressor failure you want to only flow the wash reverse to air flow.
On a real dirty one I have put in a couple of gallons of solvent and let it soak and rinse it out then wash with the best soap you can find, I prefer the citrus type cleaners, I buy those in bulk.
After you have cleaned it you want to test it, 35lbs air and when the air is shut off it must not loose any more than 4 lbs in 15 seconds. All boots, you want to clean and wipe them. and when installing use soapy water to insure the clamps tighten evenly around the full circumference of the clamp.
Just a thought!
Johnp3 is offline
post #9 of 10 (permalink) Old 07-06-2011, 04:49 PM
Every diesel ive owned ive always pulled my intercooler piping prior to doing ccv mod to get all of the rerouted oil out of my tubes. I simply remove all the piping. Clean teh boots and clamps. For the pipes I use citrus based cleaner and spray the inside of the piping, take a coat hanger and cloth and clean all the residue out and then a second pass with soap and water and then just a dry clean rag. Let the pipes dry overnight and then use hairspray on the insides of the boots to help them stick to the piping and not blow off under load.
slowcoupe is offline
post #10 of 10 (permalink) Old 07-13-2011, 02:42 AM Thread Starter
Hairspray would've been a nice touch. I just tightened my clamps down until they didnt move. The intercooler was a b* to get out.
cleaning egr? UNCLE JuJu 2003-2007 6.0L Power Stroke 15 11-11-2010 04:53 PM
bank intercooler piping(with a stock style intercooler) install question Jjona5 1994-2003 7.3L Chips & Tuners Forum 1 09-13-2009 12:46 PM
reliable efficient and powerful AmarilloSD 2003-2007 6.0L Power Stroke 20 01-31-2009 05:10 PM
Intercooler Cleaning rsjohnsn General Ford Truck and Excursion 2 01-24-2009 11:36 PM
Most fuel-efficient cars for 2006 wideopen The Parking Lot 12 10-14-2005 12:01 PM
