Up grade help needed !!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Raineysmotorsports, this thread has received 61 replies and been viewed 6677 times.
post #1 of 62 (permalink) Old 07-07-2011, 08:44 PM Thread Starter
I have a 99. 2500 has ho pump and nigh transfer pump that reg to 9 psi and I just got a edge ez with out switch I was wondering what to do next I wanted to buy some 150-200 inj and maybe have some turbo work done what should I do ??? Thanks for help Andrew
Raineysmotorsports is offline
post #2 of 62 (permalink) Old 07-07-2011, 09:56 PM
BUCK2's Avatar
Welcome to the Garage. Tell us what your plans are for the truck, daily driver, race, towing, sled pulling, etc... that will help us give you a better guidance on what to do. Also fill out your sig so we can see if your truck is an auto or manual and a 2wd or 4x4. take a look at my sig and you will get the idea.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #3 of 62 (permalink) Old 07-08-2011, 12:56 AM Thread Starter
It a 4x4 5 speed and I wanting to pull a 25 ft goose neck and maybe pull in stock class in fair local only !
post #4 of 62 (permalink) Old 07-08-2011, 01:41 PM
First what is your budget? Next what are the rules at the pulls?
later is offline
post #5 of 62 (permalink) Old 07-08-2011, 11:15 PM Thread Starter
Mostly street legal one turbo but thier sendingme the rules next week I bought the ez and it not fit should I get juice or what ?
I have 5 trucks and two drag atvs so money it spread thin to each one lol
post #6 of 62 (permalink) Old 07-09-2011, 01:57 PM
I have had Edge Comp and Drag boxes but I would like to try a Red line.
Really need to know how much you want to spend, building the engine is just part of it, you will need traction bars and a clutch or Torque Convert some transmission parts (cooler, ect.) Tires you can see the budget will tell you what you can do?
later is offline
post #7 of 62 (permalink) Old 07-09-2011, 02:42 PM Thread Starter
Money just depends I plan on buying stuff and adding little buy little maybe allow 250.00 month for this build it pulls great now I just want add some hp but I understand that if I add to much I need clutch and bigger turbo but I like to keep it down to were I could pull a 800 mile round trip to a race !
I was thinking of a hx40 turbo 150 hp inj and a programer That sound good ?
Or can I up grade my hx35 ?
Thanks for the help !
post #8 of 62 (permalink) Old 07-09-2011, 06:24 PM
A HX40 is a well upgraded HX35.
Save your money and do more at one time. Get a plan on where you want to be and not be trading part, they get expensive and time consuming.
To get a 24V to 300 hp is easy.
Your HX35 will support that and it will be a welcome power improvement.
Get a better air filter.
Get a 4inch turbo back exhaust
Get some 100 hp sticks any more will be hot and smokey.
Do what you need to make 32-35 psi of boost, anymore is just a waste with a HX35.
Your choise of boxes.
That should get you close if not a little more. If you are currently stock then you should be making 180 hp to the wheels now.
Don't get crazy until you have all the right parts. If you want a monster pump, then a box will not make much difference.
Form a plan so you are not changing turbos and injectors every week and wasting money, unless you just have more than you need.
later is offline
post #9 of 62 (permalink) Old 07-09-2011, 06:31 PM
Driving any vehicle to a race and racing it and expecting it to get you home is a bad idea. About 35 years ago my brother did that and broke a axle, needless to say I had to find a trailer and make a haul. It is great to have a daily driver but you will need a back up plan just in case something breaks, like a transmission input shaft.
later is offline
post #10 of 62 (permalink) Old 07-09-2011, 10:22 PM Thread Starter
I drive it to ATv drag races pulling a 24 ft box inlike to get in 450 hp range !
up grade time Bandersnatch 2003-2007 6.0L Power Stroke 2 05-25-2010 01:41 AM
oil grade? MART5.9 5.9L Cummins (2003-2007.5) 9 11-18-2009 10:52 PM
3rd grade RussK The Parking Lot 5 08-26-2009 02:46 PM
Grade Braking.... ymmot 2003-2007 6.0L Power Stroke 19 09-04-2007 06:31 PM
Oil Grade? Silver 6.7 6.7L Cummins (2007.5-2011) 5 05-26-2007 11:08 PM
