Adjusting transmission bands - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 2 replies and been viewed 5623 times.
post #1 of 3 (permalink) Old 08-10-2011, 05:46 AM Thread Starter
BlowinSmoke's Avatar
During or after the pan draining and filter change how do you adjust the bands like the manual says?
BlowinSmoke is offline
post #2 of 3 (permalink) Old 09-03-2011, 10:35 PM
bmoeller's Avatar
http://dodgeram.org/tech/transmissio...T_band_adj.htm
I always back the final adjust 1 more full turn than stated. Better to be a tad bit looser than too tight.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 3 (permalink) Old 09-27-2011, 02:49 AM
Like mentioned above going a tad loose is generally better, The rear band is fine at 3 turns out as it is only manual low and reverse. Front band, I often times start around 2-1/4 turns out instead of 1 7/8, and back it out as necessary to avoid hanging the 2-3 shift. If you know your clutch clearances are on the looser side of spec, going looser with the band won't hurt. also depends on servo and apply lever ratio. In my experience, start a little looser than spec, and then keep checking and adjusting by driving until you don't have it hanging that shift anymore, if it ever did to start with.
transmission bands gon2sea 5.9L Cummins 12 Valve (1994-1998.5) 8 03-25-2010 09:28 PM
Transmission Bands???? Cummins-ECL 5.9L Cummins 12 Valve (1994-1998.5) 3 09-29-2009 06:23 AM
Tranny Bands? Brand-Xrugger 5.9L Cummins (1998.5-2002) 18 06-17-2009 12:55 PM
SKYZAKYTE my bands new name AUSSIEDAVE The Parking Lot 10 01-11-2009 02:43 AM
47RE Bands Smokem Dodge Performance Forum 3 04-08-2006 06:34 AM
