lift pump pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by quattroroad, this thread has received 11 replies and been viewed 10087 times.
post #1 of 12 (permalink) Old 08-11-2011, 11:02 AM Thread Starter
Norwegian Member
lift pump pressure
hey guys, i just mounted edge juice w/attitude cts on my 99 truck yesterday.
and i noticed that the fuel pressure in dropping to 5 psi when i floor it in level 4-5. i also got fass lift pump, but havent mounted it yet. what is the correct fuel pressure, and shall it drop when i floor it?
thanks
x 2003 qc Dodge Ram 2500
5" exhaust, s&b intake, cfm+, edge juice w/attitude, smarty S-06, gauges, ddp 90hp+, arp head studs, spaerco intercooler, super b special, glacier lift pump, 20" rims
2000 Dodge Ram 2500 Sport, Edge juice w/attitude cts, fass lift pump, 4" exhaust,
quattroroad is offline
post #2 of 12 (permalink) Old 08-11-2011, 01:24 PM
ADMIN/MAFIA
neeltburn's Avatar
16PSI at Idle and not dropping below 10psi @ WOT on your FASS. The stocker is prolly not doing much over 8-10psi at idle.
Running the fuel pressure below 10psi for long will cause the VP44 injection pump to fail.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 12 (permalink) Old 08-12-2011, 01:06 AM
Dinner's Avatar
Agreed^^ Main thing is keeping that fuel pressure above 10psi for WOT
2001 Dodge 2500 4X4: Goerend, TST, Smarty, MVP, BD Rad, Injectors, Two Turbo's, Snow Performance, Supporting Mods...
12.7 @ 108mph Aug 2011
Canadian Club Member #14
Dinner is offline
post #4 of 12 (permalink) Old 08-13-2011, 12:50 AM Thread Starter
Norwegian Member
Ok, thats what i thougt.. Actually it dropped to 2 psi for a little second, ****!!
Need to get in that fass fast.. Thanks guys
post #5 of 12 (permalink) Old 08-24-2011, 02:20 AM
That is not good.
later is offline
post #6 of 12 (permalink) Old 09-04-2011, 06:55 PM Thread Starter
Norwegian Member
got in my fass pump in yesterday, and i got 15-16 psi at idle, but when i floor it it drop to 5-6 psi!? could it be the fuelfilter is bad?
I see that bd diesel have some banjo upgrade, will this help?? ****!!
thanks
post #7 of 12 (permalink) Old 09-05-2011, 01:08 AM
ADMIN/MAFIA
neeltburn's Avatar
How are you reading lift Press?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 12 (permalink) Old 09-05-2011, 02:17 PM Thread Starter
Norwegian Member
I read it via my edge juice cts, with a banjo on the inlet tube on the vp44...
post #9 of 12 (permalink) Old 09-05-2011, 03:12 PM
ADMIN/MAFIA
neeltburn's Avatar
I would try and put another gauge on it and see if the edge is telling you the truth. I would not suspect you would pull the pressue dow. On a FASS that much.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 12 (permalink) Old 09-07-2011, 04:51 PM
what fass and how installed
01quadcab is offline
I need an injection pump and an aftermarket lift pump for my 98.5 24v CRAZY ROB Dodge parts wanted 2 02-10-2010 06:35 PM
Injector Pump and Lift Pump are toast. Now What? 6thFrame 5.9L Cummins (1998.5-2002) 21 05-19-2009 09:32 PM
lift pump pressure?? dangerous196 5.9L Cummins (2003-2007.5) 4 04-20-2008 03:57 PM
Lift Pump Pressure tholt846 5.9L Cummins (1998.5-2002) 12 08-21-2007 01:48 AM
ACCEL 110GPH Fuel Pump/Lift Pump maxxis_mudder Whats Been Sold 0 12-10-2006 03:24 PM
