trannys having trouble shifting, advice? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by coreyk, this thread has received 0 replies and been viewed 791 times.
post #1 of 1 (permalink) Old 08-15-2011, 12:23 PM Thread Starter
I have a 2001 dodge ram 2500 diesel, with the 47re transmission. I changed the fluid and filter about 700 miles ago, and now the trans has trouble shifting from 2-3, if i go past 1700rpm it will not shift from 2-3 untill i baby the rpms down below around 1700rpm. Is it worth my while replacing the governor pressure solenoid and transducer? Also the trans sometimes does not downshift when coming to a stop, sometimes it will start out in 2nd or 3rd. The truck has 296k on the original trans so i know i need to get it rebuilt just trying to save the money for it, but in the meantime do you think the governor pressure solenoid and transducer will solve my problem for a while? thanks in advance!
coreyk is offline
spicer 6+1 blues. trouble with 1 and 3, advice? johndear720 Medium and Heavy Duty 21 04-21-2009 04:44 AM
Low power trouble shifting Altitude Adjuster 5.9L Cummins 12 Valve (1994-1998.5) 2 04-17-2009 08:53 AM
Trannys? superstroker17 2003-2007 6.0L Power Stroke 78 03-10-2009 11:02 PM
I Need Some Advice, girl trouble Dual K20s The Parking Lot 31 06-06-2007 07:20 AM
Trannys maddogg1019 GM Transmissions 5 02-14-2007 02:53 AM
