What should I look for - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 06F450, this thread has received 0 replies and been viewed 782 times.
post #1 of 1 (permalink) Old 08-17-2011, 10:29 PM Thread Starter
Dually Club Member #96
06F450's Avatar
Im getting ready to get an 2002 2500 sport, 4x4. Ive had a Ford since 99, im familuar with the powerstroke. I know nothing about Dodge. The truck was used to tow a 3 horse trailer, now it just sits, driven once a month. The truck is and has been bone stock. Going Friday to do a test drive and maybe paperwork. Any help would be a great help. Looking to see about, common leaky spots, common repairs, or anything that i should be concerened about. Thanks for reading.
2006 F450
SCT X3 Tuner (with EGR Off), A.R.P. Studs, AiRaid Drop In Filter, AutoMeter Pyro, Zoodad Mod, CCV Reroute, Hollowed & Piped Kitty, 4" Kitty Back Blown Coal in Front Of Rear Wheel, F550 Brakes, Splicer Rear End W/ 4:30 Gears, High Idle Mod, 12'x8' Harbor Contractor Combo Bed, More To Come After Economy Picks up. 13k All Day... Everyday
WARRANTY WORK :
(2) Altenators, (2) Batteries, (6) Sensors, (1) Turbo, (1) Full Engine Harness, (1) E.G.R. Cooler, (3) E.G.R. Valves, (1) I.C.P. Sensor... Hopefully thats it??? UPDATE10,2010; All Dummy Plug Seals, 2 fuel injectors, ECM, Both Silicon Boost Hoses, Clean Turbo... im sure theres more to come
7-2011 E.G.R. Cooler, Oil Cooler, Gaskets, Clamp, Filters, Fluid, Other BS... $1000 Work Done In Garage.
11-2-2011 Head Gaskets, degas bottle with cap, ring for turbo, egr cooler, temp sending sensor, radiator, thermostat, ficm, glowplug module, fluids, filters, and other gaskets... Material, tax, labor at dealer... $5900
A.R.P. studs... $466
11-15-11; Egr valve, and crank position sensor
06F450 is offline
