what twins and injectors? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by quattroroad, this thread has received 18 replies and been viewed 5528 times.
post #1 of 19 (permalink) Old 08-21-2011, 12:18 PM Thread Starter
Norwegian Member
hey, I`m looking for a compound set and some injectors. I want to hit 500+whp, but keep it so driveable as possible... I`ve seen on this set http://www.pdrdiesel.com/products/Co...s-685-162.html , but also ATS...
what are your experience of these twins??
also how big injector nozzles does the vp44 pump handle?
thanks
x 2003 qc Dodge Ram 2500
5" exhaust, s&b intake, cfm+, edge juice w/attitude, smarty S-06, gauges, ddp 90hp+, arp head studs, spaerco intercooler, super b special, glacier lift pump, 20" rims
2000 Dodge Ram 2500 Sport, Edge juice w/attitude cts, fass lift pump, 4" exhaust,
quattroroad is offline
post #2 of 19 (permalink) Old 08-24-2011, 02:16 AM
You can build a set of twins using your HX35 for the top and a HT3B or S366 or S471 for the primary, should have enough air for 500 hp, and build your exhaust when you make the decision on the twins set. For injectors 120 hp stick. You will need a good fuel transfer pump. And a better air cleaner. What fuel box are you going to run? The edge would be ok or are you wanting more? And you will want to O-ring the head and install studs.
later is offline
post #3 of 19 (permalink) Old 08-25-2011, 02:51 PM Thread Starter
Norwegian Member
I am running the edge juice w/attitude cts, looking to get the hot unlock. My stock turbo is getting a bit tired, so i need to replace it anyway, so i'm looking for a comlete set. I will also get a set of head studs, but not o-ringed yet. I was looking at the 150hp ddp injectors, but is this too much for the vp44?
Thanks
post #4 of 19 (permalink) Old 08-25-2011, 06:52 PM
BUCK2's Avatar
I am running a Borg Warner 57/65/12 over a S475. I bought all of my piping from Source Automotive. It was very easy to install and performs really well. I also wrapped bothe turbos and the hot pipe and the down pipe in heat wrap to help with the under hood temps. I have about 3500 total in my set up.
If you are some what mechanical it is easy to do and eveything was a direct bolt up. Good luck.
You will want to make sure that you have an aftermarket lift pump like a FASS or Air Dog. The VP's need it worse than the P-pump trucks. BTW that is my nest purchase is the Air Dog.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #5 of 19 (permalink) Old 08-26-2011, 12:05 AM
Thanks
They will work.
later is offline
post #6 of 19 (permalink) Old 08-26-2011, 09:35 PM
whats your hp goal? then we can figure out turbos and injectors
01quadcab is offline
post #7 of 19 (permalink) Old 08-26-2011, 10:38 PM Thread Starter
Norwegian Member
My hp goal is 500+hp...
post #8 of 19 (permalink) Old 08-27-2011, 12:10 AM
Head studs,
O-ring,
Towing Twins, maybe the R700 upgrade, or something like them,
150 hp injector.
later is offline
post #9 of 19 (permalink) Old 08-27-2011, 06:00 AM
I made 575 with a 362 over a 475 with 200hp ddp injectors. but yes studs and o-ring are a must.
post #10 of 19 (permalink) Old 08-27-2011, 01:44 PM
That sounds like you ran out of fuel.
later is offline
12v build advice, Q's about injectors and twins. BigRed Cummins 5.9L Cummins 12 Valve (1994-1998.5) 5 05-13-2009 04:34 PM
about twins quattroroad 24 Valve Performance 22 04-12-2008 09:29 AM
6.0 twins BogginF350 2003-2007 6.0L Power Stroke 17 10-19-2006 02:41 AM
injectors with twins diesel_ram_man 5.9L Cummins (2003-2007.5) 2 06-09-2006 01:41 AM
Looking for twins Carl Dodge Performance Forum 5 05-29-2006 09:11 PM
