hot 5spd cooler? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skidly, this thread has received 3 replies and been viewed 1137 times.
post #1 of 4 (permalink) Old 08-24-2011, 11:48 AM Thread Starter
hot 5spd cooler?
When towing my nv4500 is getting up to 252 degrees, I just replaced transmission and I want to make this one last. What can I do ? Guys around here are running an extra quart of oil in trans., is this a good idea? Who makes the finned pto covers? thanks
skidly is offline
post #2 of 4 (permalink) Old 08-24-2011, 05:24 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
ya lil extra oil is good but not to much as the oil helps pull the heat from the trans oil also retains heat theirs a point of diminishing returns,as for the coolers. they are called "fast coolers" google it. By adding the coolers you are on the right track as you are not so much as adding oil but adding capacity which is more important and more effective
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #3 of 4 (permalink) Old 08-24-2011, 05:30 PM
BUCK2's Avatar
I am running coolers on mine and it has helped out alot! They are cheap and easy to install. It is the expense of the fluid that makes it expensive. But you will like it!
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #4 of 4 (permalink) Old 08-25-2011, 12:04 AM Thread Starter
thanks guys, I knew I'd find some help here ! I appreciate it.
skidly is offline
Adapting oil cooler to trans cooler 4L80E. . . M123KT-450 GM Transmissions 16 08-15-2009 10:44 PM
5spd to 6spd Cummins Diesel GM Transmissions 1 01-22-2008 10:15 PM
Would Banks Techni-cooler Help Save The Egr Cooler From Failing? nemotorcars 2003-2007 6.0L Power Stroke 9 01-01-2008 08:42 PM
96 ext cab 12v 5spd FF4431 Whats Been Sold 10 12-15-2007 10:00 PM
Trying to build a ZF 5spd Trans Cooler WyoDieselCowboy 1994-2003 7.3L Power Stroke 6 02-28-2007 12:05 PM
