truck surgeing,rev up? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MILKINGCOWBOY, this thread has received 7 replies and been viewed 1843 times.
post #1 of 8 (permalink) Old 08-24-2011, 05:21 PM Thread Starter
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
Question truck surgeing,rev up?
Hey yall,
Been a lil while.....Ok between 1,500 and 2,200 rpm mainly some times the truck will rev up or surge on its own. almost as if I lightly tapped the pedal and let right off. Also when I let of the pedal some the there is very little"lag" it decrease rpm very fast like it was loaded. kinda slight jerky feeling.Makes shifting feel a lil awkward The only two things I can relate it to is one I used to have a real nice built big block Chevy that was super responsive and tried different return springs on the throttle and with a light one on it it kinda felt like this not very drivable...or when I hold a steady pedal and increase or decrease my "edge" level it feels the same way very much so. with the slight burping or jumping in the rpm. It dose it most of the time. It dose it from stock setting to #5 on the juice I do notice it more on 5 which makes sense as the engine is more responsive on 5 normally. It dose this all while I am holding a steady pedal. I am resetting the apps as we speak. fuel pressure stays pretty steady around 16,any other ideas thanks
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #2 of 8 (permalink) Old 08-25-2011, 02:33 AM Thread Starter
milkin cowboy
pS no codes. also it does not seem to do it om cruise.... But When it dose it it kinda feels like if the truck was on cruise and hit a small hill the way the cruise comes in and accelerates
KEEP ON KEEPIN ON
post #3 of 8 (permalink) Old 09-02-2011, 04:17 PM Thread Starter
milkin cowboy
any help please
come on guys I know some one has something
KEEP ON KEEPIN ON
post #4 of 8 (permalink) Old 09-03-2011, 01:42 AM
The first box, tuner I put on my truck was a Bank's and it would do that. So I switched to a Edge and it stopped. What box are you running?
later is offline
post #5 of 8 (permalink) Old 09-03-2011, 05:25 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
My brothers 99 did similar to wat yours does although he also had the dead pedal issue tried a new TPS and resetting the apps neither worked...but when we had the alternator looked at since it was a reman Oreilly's we found some bolts had worked themselves loose causing a short and all sorts of funky chit going on had it rebuilt and no problems another 10k down the road
Military Quote Of The Year
SOOTBANDIT is offline
The Following User Says Thank You to SOOTBANDIT For this addition to TDG:
MILKINGCOWBOY (09-03-2011)
post #6 of 8 (permalink) Old 09-03-2011, 11:25 PM Thread Starter
milkin cowboy
edge juice
KEEP ON KEEPIN ON
post #7 of 8 (permalink) Old 09-05-2011, 03:17 AM
Originally Posted by MILKINGCOWBOY View Post
edge juice
I don't know, it should be ok.
later is offline
post #8 of 8 (permalink) Old 09-05-2011, 05:43 PM
i had a 98.5 that did the same thing with no codes. and in turned out to be a dead vp. i would deff make sure all your connections are tight especially the pump wire tap. try taking the edge right off and see if it still does it, could be a fautly box.
24vman is offline
The Following User Says Thank You to 24vman For this addition to TDG:
MILKINGCOWBOY (09-07-2011)
Good donor truck for race truck Superdutytd General Ford Truck and Excursion 0 10-07-2009 09:43 PM
my truck and a buddies truck at ocotillo pics dieselboy740 4X4 Offroad Forum 16 11-19-2007 10:53 PM
Surgeing problem dbunyip 1994-2003 7.3L Power Stroke 6 10-16-2007 06:33 PM
had my truck at the local truck pull to night SmokingIDI_7.3L 7.3L and 6.9 IDI (Pre 1994) 3 06-17-2007 06:24 AM
NASCAR Truck Series - Powerstroke truck sredish General Ford Truck and Excursion 14 07-01-2006 12:25 PM
