Oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bruno2, this thread has received 3 replies and been viewed 1092 times.
post #1 of 4 (permalink) Old 09-15-2011, 10:55 PM Thread Starter
Bruno2's Avatar
Oil leak
My neighbor has a truck in his driveway with a severe oil leak. The owner took it to a shop and they said something along the lines of the lifter cover leaking. Is there such an animal and does it leak? Where the hell is it and what's the easiest way to change it?
7.3 psd ,Z-F5 , ARP headstuds , ARP main studs , D-66 dominator Turbo ,EBPV delete pedestal , MBRP 4" straight pipe , Rosewood stg II's , Tony's tunes 6 pos, K&N gen II intake ,comp 910 springs , Hurst line lock . Ford IC, Banks piping kit .
Alpine deck
Rockford Fosgate subs
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
HD leaf springs ,Over sized drive shafts , heavy duty precision u-joints all the way around
B.O.M.B. squad member #39
Singles Club member #251
Walnutter #8
Bruno2 is offline
post #2 of 4 (permalink) Old 09-23-2011, 10:12 PM
BlowinSmoke's Avatar
Pin pointing it would be best, clean it all off and run the engine. You can also find dyes to add to the oil and use a black light on it.
BlowinSmoke is offline
post #3 of 4 (permalink) Old 09-27-2011, 02:43 AM
Do they mean the valve cover, or the tappet cover on the drivers side of the block? They do exist, and generally the cause of the leak is do to high crankcase pressure and inadequate crank case ventilation. But once they start leaking they need a new seal.
post #4 of 4 (permalink) Old 09-27-2011, 06:35 PM
If the oil level is to high and you run it at High RPM it will blow it out some have a vent, and hose off that cover as well. First thing I would do is check the oil pan level, 15 quarts, 14.2 liters, that is the oil pan level, you can drain the oil and with a graduated jug add the old oil back to that amount leave it for 10 minutes and that is the level. You can cut the tube if it is a cane type or remark the stick. Then clean the vent, and hose at the front.
Johnp3 is offline
OK fuel leak stopped now oil leak Stacked6600 1994-2003 7.3L Power Stroke 7 01-27-2011 03:37 AM
99 f-450 7.3D oil pan leak help! Twin Star Farm 1994-2003 7.3L Power Stroke 2 08-06-2009 10:46 AM
Oil Leak BigN8 1994-2003 7.3L Power Stroke 11 04-04-2007 07:53 PM
Oil Leak baracr475 2003-2007 6.0L Power Stroke 9 03-30-2007 11:22 PM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
