99 To 01 Swap.....Trans not right!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99Cummins24V, this thread has received 2 replies and been viewed 1037 times.
post #1 of 3 (permalink) Old 10-18-2011, 12:05 AM Thread Starter
I swapped out my junk 99 motor for an 01 motor. Just swapped out the ECM's for the 01 ECM's. Now I don't have 4th gear or lock up. I can get 3rd gear lock up if I use my switch but still no 4th. Wondering if this is a re flash issue or something else. I had 4th and lock up when I put it in the garage to swap ECM's and when I pulled it out 30 mins later it wasn't there. The ECM was for an 01 cummins 2500 with an automatic trans. Mine is a 99 cummins 2500 with an automatic trans. Any help would be great!
99Cummins24V is offline
post #2 of 3 (permalink) Old 10-18-2011, 05:23 PM
it's the valve body solenoids. they are different between the years. swap them out and life will be good.
01quadcab is offline
post #3 of 3 (permalink) Old 10-18-2011, 10:00 PM Thread Starter
Okay cool. I was also told today the PCMs form 99 to 01 maybe pinned different for lock up and the 3-4 shift. I just don't know what pins to look at. I can't find a diagram for it.
Trans swap idea ?????? ChrisSheerman 1994-2003 7.3L Power Stroke 11 11-16-2010 03:51 AM
trans swap ipkyss 2008-2010 6.4L Power Stroke 2 09-23-2010 08:18 AM
trans swap? 97idi 7.3L and 6.9 IDI (Pre 1994) 0 08-16-2009 02:37 PM
Trans swap question colorado7.3 7.3L and 6.9 IDI (Pre 1994) 2 03-02-2008 06:58 PM
4L80E Trans swap in '97 ORIguy 5.9L Cummins 12 Valve (1994-1998.5) 9 07-24-2006 08:39 PM
