2002 shuting down - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acegreaser, this thread has received 7 replies and been viewed 1576 times.
post #1 of 8 (permalink) Old 11-09-2011, 04:11 PM Thread Starter
2002 shuting down
Have 02 started surging at idle now it shut down going down the road.It will start right back up.Getting worse no codes.Going to check fuel pressure new lift pump 30k ago.Fount rust in filter housing lift pump sounds noisey now.But there is no misfire or white smoke just like it was shut off with the key.Changed the cam sensor didn't make a difference.
acegreaser is offline
post #2 of 8 (permalink) Old 11-10-2011, 03:37 PM
ADMIN/MAFIA
neeltburn's Avatar
Could be early signs of lift pump failure, see if you can get a gauge on it and see what its pushing. Could also be a fuel filter, there should not be rust in the filter bowl. Surging could also be related to the APPS sensor.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 8 (permalink) Old 11-11-2011, 11:53 PM Thread Starter
was told that it could be faulty injector compression sealing gaskets,truck stumbles or stalls at idle but not all the time,sometimes while driving almost like a misfire or backfire.
post #4 of 8 (permalink) Old 11-12-2011, 02:04 AM
ADMIN/MAFIA
neeltburn's Avatar
Sounds like its time to pull the injectors and have them pop tested that way you are sure of that is the problem, but it sounds like injector time.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 8 (permalink) Old 11-15-2011, 04:24 PM
lift pump will do the same thing too. the vp will pull enough fuel to idle but no more if the lines are plugging up with rust it may not even be able to pull enough to idle might be time for new lines, or just save the hassle of that and put on a fass
01quadcab is offline
post #6 of 8 (permalink) Old 11-16-2011, 12:09 AM Thread Starter
put a clear filter in before lift pump.Put new lift pump in.Truck still shutting down or sputtering randomly.Sometimes runs fine half the day.Voltage to the vp is good.
post #7 of 8 (permalink) Old 11-16-2011, 07:04 PM
what filter are you running before lift pump? it's not stock then. also a new factory lift pump will not run very well if it gets crap in it. they are a waste of money. they can live 2hrs or a long time you just never know what your getting.
post #8 of 8 (permalink) Old 12-03-2011, 03:08 AM
Check everthing from the fuel tank to the injectors, but it sounds like the VP died. More than likely you will need a new lift pump, fuel filter, and a VP injection pump. Good luck.
later is offline
2002 f-250 fedman Vehicles For Sale 4 02-22-2010 02:52 AM
HID for a 2002 f-250 Blackmax 1994-2003 7.3L Power Stroke 1 10-19-2009 02:58 PM
2002 7.3 Ecm 99fordtruckguy Whats Been Sold 4 02-03-2008 04:34 PM
2002 Help!!!! MaxRoadArmor Duramax 2001-2004 (LB7) 9 12-07-2006 06:00 PM
2002 F-250 crzycowboy Ford Oasis requests 2 02-09-2006 10:05 AM
