torque converter or clutches? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rollincoal97, this thread has received 2 replies and been viewed 1095 times.
post #1 of 3 (permalink) Old 02-08-2012, 02:44 PM Thread Starter
rollincoal97's Avatar
Im fairly unfarmiliar with automatic trans. so im not sure which is going out on my truck. Did a trans. oil anaylisis and iron levels are normal but feels like either my torque converter or clutches would be slipping.Truck just doesnt put the power to the ground like it use to. Its a stock trans and TC so im not suprised with about 125,000 miles. What are some of the giveaways i guess you could say, as to what is slipping or failing? Thanks
2001 dodge cummins 24v automatic daily driver, quad cab long box, sport/slt package, AFE stage 2 intake, stock exhaust straight piped, EDGE Comp box, fass fuel pump, plugged wastegate, 33x12.5x17 PRO COMP tires and rims
rollincoal97 is offline
post #2 of 3 (permalink) Old 02-08-2012, 08:30 PM
I would pull the pan and change the internal filter, that being dirty can restrict the flow of oil and cause all kinds of problems.
If you find any brass in the pan the transmission is done.
Those transmissions are a very week point of the truck.
I have a guy that does transmissions, all kinds, all brands, and he spends at least 50% of his time on the 5 speeds in the Dodges.
Johnp3 is offline
post #3 of 3 (permalink) Old 02-15-2012, 07:10 PM Thread Starter
Are there certain things while driving to watch for, to help pin point it more also?
Torque Converter Ap diesel 2008-2010 6.4L Engine Tuner Forum 0 01-31-2012 03:45 AM
OBS torque converter imported_whitelightning 1994-2003 7.3L Power Stroke 2 12-02-2007 07:27 PM
Torque Converter... Cummins_Beast 1994-2003 7.3L Power Stroke 5 11-04-2007 01:11 AM
Torque Converter 00Excursion General Ford Truck and Excursion 5 05-20-2007 11:03 AM
torque converter john14310 1994-2003 7.3L Power Stroke 8 05-30-2006 10:19 AM
