Dont know what happend??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 02sprtcumns, this thread has received 10 replies and been viewed 2674 times.
post #1 of 11 (permalink) Old 03-21-2012, 09:33 PM Thread Starter
02sprtcumns's Avatar
Well today i was getting on the interstate eveything was fine. I got up to speed noticed the check engine light came on. Tach started jumping like crazy. I pulled off ran the codes. I got 0500, 0341, 1690, 1693. The truck will start fine and idle fine just running will jump a little fuel psi is 14-15 at all times. Any ideas?????
02sprtcumns is offline
post #2 of 11 (permalink) Old 03-23-2012, 02:02 PM
98whitelightnin's Avatar
Sounds like a cam shaft position sensor.
98 Dodge 24v, Edge Comp, Contagious Diesel 7x.010, BHAF, 3rd gens wrapped with 305 Nitto's
98whitelightnin is offline
post #3 of 11 (permalink) Old 03-26-2012, 09:13 PM Thread Starter
How bad is this to fix. First time i have had this happend to any of the Cummins ive had.
post #4 of 11 (permalink) Old 03-29-2012, 08:57 PM Thread Starter
Put the new sensor in today cleared the codes drove 5 miles perfect. Stop restarted the truck check engine light again and worse???????? makes no sense
post #5 of 11 (permalink) Old 03-31-2012, 12:22 AM Thread Starter
Took the cam sensor out and done everything over. Started truck no engine light turned it off and back out engine light is on and running like hell. Codes today are
P PCU
Done
P ECU
0122 - TPS Voltage Low
0237 - Map sensor voltage low
1690 - Injector pump CKP sensor Dont agree with ECM CKP sensor
0341 - Camshaft position sensor signal
1475 - Aux 5 volt supply voltage high.
Were do i start Crank sensor or what?????
post #6 of 11 (permalink) Old 03-31-2012, 01:55 PM
Combat Trucker
hillbilli's Avatar
Could be a long shot, but check for loose bolts behind the fusebox and loose wire connections.
07 Ram 2500 5.9 Megacab
96 k2500 Extcab 6.5TD vin F NV4500 3.73 245k miles
07 Hemi Durango
03 Ram 2500 (Gone but not forgotten)
hillbilli is offline
post #7 of 11 (permalink) Old 04-01-2012, 07:06 PM Thread Starter
Well checked everything still running bad. Checked codes now I 0606 code with everything else. Should I just take it to the local dealership and let them put the ECM in or should I do different?
post #8 of 11 (permalink) Old 04-07-2012, 02:51 AM
Have you checked the battery ground on the block? Sometimes it will become corroded and cause problems.
later is offline
post #9 of 11 (permalink) Old 04-10-2012, 12:07 AM Thread Starter
Yeah i have checked everything it ended up going to the dealership and the ecm replaced it was completely shot!! 1500 later i got it today back to running good.
post #10 of 11 (permalink) Old 03-17-2013, 01:35 AM
I got same problem but I got a bunch of codes pcu codes 1682 0622 0320 1694 1693 ecu codes 1693 1698 0232 1690 0341 0230 need major help have no idea what's going on
gray ghost is offline
Radio stays on.. door locks dont work... auto lights dont work... help!!!!! sittinclean 1994-2003 7.3L Power Stroke 4 03-30-2009 05:19 PM
Hey GTS motorsports what happend to your site imported_whitelightning 1994-2003 7.3L Power Stroke 2 04-04-2008 12:53 AM
Dont fret, Dont fear,..Im finally here TANK'S 250 2003-2007 6.0L Power Stroke 32 01-13-2006 01:47 PM
