Broken dipstick - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ODR, this thread has received 2 replies and been viewed 2013 times.
post #1 of 3 (permalink) Old 03-22-2012, 01:26 AM Thread Starter
ODR
Broken dipstick
I broke the handle off my my dipstick tried to put a screw in the top to extract the rest of it with no luck. Figured I would take the tube off and push it out from bottom but it looks like it is pressed into the oil pan. Does any one know how to get it out?
I am here: http://tapatalk.com/map.php?uefbqo
ODR is offline
post #2 of 3 (permalink) Old 03-22-2012, 05:25 AM
bmoeller's Avatar
If the 24v was done the same as my '92, there is a steel insert in the block that the plastic tube is attached to.
Remove the clamp at the bottom and cut the tube vertically to free from the insert with a knife.
Will most likely need to pull the stater to get at it easier. I did, though the insert was broke on my truck. Puked a LOT of oil out!
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 3 (permalink) Old 03-27-2012, 04:26 PM Thread Starter
ODR
The tube looked like it was pressed into pan. So I called local mechanic (what I should have done in first place because he is quite a few handy little tricks up his sleeve for odd ball stuff like this ). He told me to heat a ribbed nail and poke it in there and let it cool and it will pull right out. Worked like a charm!
I am here: http://tapatalk.com/map.php?jnw2ef
ODR is offline
Oil coming out of the dipstick! mopar440cu 5.9L Cummins (1998.5-2002) 28 03-13-2012 03:07 PM
im looking for a dipstick and the pipe.... biz 1994-2003 7.3L Power Stroke 0 12-02-2009 09:31 PM
7.3 idi dipstick length.... MrDanB 7.3L and 6.9 IDI (Pre 1994) 6 03-30-2009 09:43 PM
7.3 idi dipstick 91/2 7.3idi Whats Been Sold 0 11-13-2007 09:11 PM
Billet Dipstick??? ymmot General Ford Truck and Excursion 2 08-29-2007 01:47 PM
