Head gasket leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ODR, this thread has received 2 replies and been viewed 1510 times.
post #1 of 3 (permalink) Old 03-29-2012, 03:56 AM Thread Starter
ODR
Head gasket leak
Head gasket leaking pretty bad at front of motor. Tried some irontite stop leak that did not work. Could I get by with just doing the gasket or do I have to get the head planed? Money is tight right now.
I am here: http://tapatalk.com/map.php?xsgbem
ODR is offline
post #2 of 3 (permalink) Old 03-29-2012, 02:12 PM
It does not sound like this just happened, so you should have the head and block checked. You should install new head bolts as well.
Stop leak may be a temp fix on a gas engine but these little diesels make way too much presure for any of those to work.
later is offline
post #3 of 3 (permalink) Old 03-29-2012, 11:30 PM
First off you want to really wash the engine off clean as posible front to back top to bottom. inspect with a mirror, to see where the leak is be sure it is not a thermostat.
You really do not want to use any stop leak, it is plugging something, heater core, radiator and will cause a lot more problems in the future, that it will ever cure now.
We use to change any that showed corrosion and the three short ones.
I would get the head checked and you get new valve guide seals with the gasket kit get them installed at least.
I personally have never seen a block distorted. You do want to draw file the deck to be sure it is flat and no dings.
Johnp3 is offline
head gasket oil leak flips Medium and Heavy Duty 9 12-04-2010 05:41 PM
'98 Dodge 12v Head studs and Head Gasket PhilipR Supporting Vendors Forum 2 10-09-2009 10:20 AM
Hypermax Head Studs and Head Gasket HotSauce2138 Supporting Vendors Forum 11 04-28-2008 04:40 PM
1991 B5.9 coolant leak - head gasket? mad2smile 5.9L Cummins (Pre 1994) 6 01-19-2008 09:21 AM
Head Gasket time should I stud it and A/M Gasket it? cdooguy 2003-2007 6.0L Power Stroke 7 04-26-2007 04:36 AM
