Which fuel transfer pump to buy? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by oldbeek, this thread has received 11 replies and been viewed 2799 times.
post #1 of 12 (permalink) Old 06-29-2012, 01:24 AM Thread Starter
Stock fuel pump only delivering 5 psi at wide open throttle in nuetral. For a old man with a rock stock truck that tows a 12,000# fifth wheel, which pump should I buy? FSS sells a replacement pump that they say delivers 30% better flow. $ 264.00 at Geno's garage. Any suggedtions?
oldbeek is offline
post #2 of 12 (permalink) Old 06-30-2012, 02:09 AM
ADMIN/MAFIA
neeltburn's Avatar
I gotta say AirDog II 100. and put you a fuel pressure gauge on it. I went down the LP and VP44 road with my 01 and would save that even at the price of the AirDog II its a deal when you price a VP44 Injection pump. I put an AirDog II 100 on my 6.7L CTD and Towing about the same weight I hold 16/17 PSI all day with a 70hp tow tune.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
oldbeek (06-30-2012)
post #3 of 12 (permalink) Old 07-05-2012, 03:49 AM
That statement kinda tell's just what kind of mechanic you are. Or would a simple question tell us more, "what is a clutch brake" I know that is a easy one.
later is offline
post #4 of 12 (permalink) Old 07-05-2012, 06:45 AM Thread Starter
This reply is for LATER. I am not to proud to ask questions. I have been out of the business for 10 years. Not being afraid to ask questions is what gave me the edge as a good mechanic and fleet manager. I can only smile while I collect my $4,000 a month retirement from my last fleet job. A clutch brake is a brake that applies in the last 1/2 inch of pedal travel to stop the clutch and main shaft from spinning.
oldbeek is offline
post #5 of 12 (permalink) Old 07-05-2012, 07:38 AM
I am glad you could figure that out, now are you saying that your current fuel transfer pump is only providing 5 psig to the VP injection pump at full throttle in netural? Or it should only provide....?
later is offline
post #6 of 12 (permalink) Old 07-05-2012, 05:04 PM Thread Starter
I felt 5 psi at WOT was not good. Wanted to know which pump would serve me best in a stock situation. Have an Airdog raptor on the way which I am going to mount on the chassis. Thanks for the reply.
oldbeek is offline
post #7 of 12 (permalink) Old 07-06-2012, 04:53 AM
You are correct 5 psig is the min.
I guess what I am trying to get at is WOT is not the peddle on the floor in netural. It would be the peddle on the floor at governor rpm under full load. You know full rack is what we called many years ago.
later is offline
post #8 of 12 (permalink) Old 07-06-2012, 05:04 AM Thread Starter
Yea and I knew 5 psi was not going to get it at wot in nuetral. Probably lot less under full power. Didn't need to test any further as i only had a bench test guage. Thanks
oldbeek is offline
post #9 of 12 (permalink) Old 07-08-2012, 03:17 AM
ADMIN/MAFIA
neeltburn's Avatar
Put a gauge on it you so you can monitor it all the time, I have an Isspro gauge that I see maybe 1psi drop with heavy foot and 5er on. ( ADII 100)
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
oldbeek (07-08-2012)
post #10 of 12 (permalink) Old 07-08-2012, 05:24 AM Thread Starter
I am installing guage with new pump. Thanks
oldbeek is offline
fuel transfer pump-3406c dondiesel444 Medium and Heavy Duty 5 10-14-2010 12:13 AM
fuel transfer pump thinbluelinetx 1994-2003 7.3L Power Stroke 1 02-18-2010 09:22 PM
Drill pump to transfer fuel Duke Utility & Farm Tractors 17 02-14-2010 03:23 AM
transfer pump??? hubcap 5.9L Cummins (2003-2007.5) 6 09-02-2007 02:14 AM
Transfer pump question bad_cummins 5.9L Cummins (1998.5-2002) 12 07-29-2006 01:03 AM
