no power,sometimes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rrimpa, this thread has received 13 replies and been viewed 2158 times.
post #1 of 14 (permalink) Old 08-07-2012, 11:23 PM Thread Starter
rrimpa's Avatar
Send a message via Skype™ to rrimpa
no power,sometimes
hi all, new to this part of forum. just bought a 2000 2500 5.9l
it is a very nice truck runs great ,until today,was hauling my tractor and every thing seemed good stopped an got some cetane boost and added it to a half tank of fuel. picked up my tractor and started home,stopped and filled my tank up,left station and going up hills it acts like the turbo is shut down. I have only had the truck for a week and a half,but I have had no problems hauling my flatbed or camper trailer. it just started today after filling up
thanks for any help
If you are not making mistakes you are not doing anything.
why are Johndeeres painted green?
so they can hide in the grass when the red tractors go by
1995 I.H. 4700 /DT466 used for hauling trailers
this is not mine,just thought it was cool
rrimpa is offline
post #2 of 14 (permalink) Old 08-09-2012, 02:31 AM
ADMIN/MAFIA
neeltburn's Avatar
With doors closed, cycle the key with out starting the engine on-off on-off-on. In the odometer codes will be displayed. Sounds like it could be the lift pump. At the top of this forum should be a sticky of codes for this model. see if you have any and report them back.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
rrimpa (08-10-2012)
post #3 of 14 (permalink) Old 08-12-2012, 03:46 PM Thread Starter
rrimpa's Avatar
well, replaced liftpump,"was bad"and filter ran good for a day then started all over again only worse,
rrimpa is offline
post #4 of 14 (permalink) Old 08-12-2012, 03:50 PM Thread Starter
rrimpa's Avatar
could a bad waste gate do this,the actuator is working but could it be broken inside? I don't know have been working on gas engines my whole life,I know how everything works just not familiar with diesel
rrimpa is offline
post #5 of 14 (permalink) Old 08-12-2012, 07:42 PM
ADMIN/MAFIA
neeltburn's Avatar
It would only be a waste gate if was stuck open, and you would hear the air coming out of it. Without codes and pressure readings I am wondering what kind of shape the vp44 injection pump is in. With a bad lift pump the VP44 injection pump could have been comprimised. Get a Lift Pressure gauge on it and see how much pressure you have. you need 16psi at idel and it not to drop below 12psi a WOT. Most stock pumps can drop as low as 8psi. The VP44s are extemely pressure sensitive and fail when they do not have the correct fuel running to them as the fuel is what lubricates the pump. I can unfortuneatly say I learned this lesson the VERY expensive way, though I still miss that truck from time to time.
Sent from my IPhone 4s An AT&T not so 4G phone via Tapatalk.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 14 (permalink) Old 08-12-2012, 07:45 PM Thread Starter
rrimpa's Avatar
I have been doing some digging,and do you think a bad map sensor could make my truck run this way?
rrimpa is offline
post #7 of 14 (permalink) Old 08-12-2012, 07:50 PM
ADMIN/MAFIA
neeltburn's Avatar
APPS/TPS and MAP "could" but w/o DTCs all I can really do is guess. Try the key trick again and Check the list found HERE ( Click Here)
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 14 (permalink) Old 08-12-2012, 07:53 PM Thread Starter
rrimpa's Avatar
the psi at the port on the inj pump is 16 at idle and about 10 to 11 psi at wot
rrimpa is offline
post #9 of 14 (permalink) Old 08-12-2012, 07:54 PM
ADMIN/MAFIA
neeltburn's Avatar
You could try and clean the MAP sensor and see if that makes a difference, Is the truck stock?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
rrimpa (08-12-2012)
post #10 of 14 (permalink) Old 08-12-2012, 07:54 PM Thread Starter
rrimpa's Avatar
my son works at a dodge dealer and is going to read it tomorrow,I will let you know what happens.
thanks
rrimpa is offline
Cheap ATS E POWER 6.0 POWER STROKE murdered out Ford Parts 0 11-07-2009 01:23 AM
FORD SUPER DUTY 6.7L POWER STROKE DIESEL - Power Rating Discussion & Poll Scorpion6.7L 2011+ 6.7L Power Stroke Diesel 7 11-03-2009 02:38 PM
Converting from non power to power seating. boosted_blazer General Ford Truck and Excursion 0 02-17-2009 02:09 PM
No power steering or power brakes bigdaddy1 5.9L Cummins (1998.5-2002) 7 01-24-2009 04:53 PM
How much additional power by turning up the full power screw? colofred 5.9L Cummins (Pre 1994) 11 04-05-2007 09:26 PM
