Code P0230 ?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by oldbeek, this thread has received 0 replies and been viewed 2998 times.
post #1 of 1 (permalink) Old 08-10-2012, 02:07 AM Thread Starter
Code P0230 ??
Transfer pump circuit out of range. Recently installed an air dog raptor and a quality liquid filled direct reading guage connected to inlet of the injection pump. I set the pressure at 18 psi. Idles at 18 psi and drops to 12psi at full throttle. I went looking for a trouble code because my trans is hunting with light throttle at 47 mph in OD. Doesn't do it in direct or heavier throttle. ANYWAY do I have too much fuel pressure or should I ignor the code P0230?
oldbeek is offline
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 02:29 AM
Code 32,33,78 Need Help titanus0111 6.5L Diesel Engine 2 08-22-2009 07:06 AM
New Code Never Saw Before SOOTBANDIT 6.7L Cummins (2007.5-2011) 6 02-17-2009 12:58 PM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 02:36 PM
Pcm Code?? allis7040 2003-2007 6.0L Power Stroke 5 08-10-2006 11:29 PM
