Opinions Plz - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Brand-Xrugger, this thread has received 1 replies and been viewed 937 times.
post #1 of 2 (permalink) Old 08-28-2012, 09:12 PM Thread Starter
Opinions Plz
I have a line on a 2002 2500 quad cab 4wd auto with 30,000 miles. Yes 30k. It was a theft recovery and the guy already rebuilt the tranny with a stage II convertor had some minor body damage that was fixed and the truck was fully painted. Never had a programmer on it and just a high ram. Bone stock. I had a 2001 that I went through the standard stuff with lift pump, VP44, Ball joints ect... what do you all think? I am stuck in a mazda3 so I need to get into something before I drive it into a tree! I just don't want to eager that I do something stupid.
Thanks
Brand-Xrugger is offline
post #2 of 2 (permalink) Old 09-21-2012, 01:30 AM
Let's see an 02 with 30,000 miles? Well it could be true. 02's Have a VP pump, if the truck is run out of fuel or the fuel filter stops up you could expect to drop about 2000 dollars for a new fuel injection pump. There is not much of a way to know if it is ok but you could pull the codes. You do that by turning the key on then off 3 times then wait and watch the odometer it will flash the ECM codes and PCM codes the say it is done. Drive it a short way before pulling the codes.
Good luck
later is offline
3.55 vs 3.73 opinions MJ351 2008-2010 6.4L Power Stroke 25 08-15-2009 12:27 AM
Need some opinions OFD343 2008-2010 6.4L Power Stroke 15 08-01-2009 05:55 AM
Tell me your opinions cuebird 1994-2003 7.3L Power Stroke 5 06-07-2007 04:52 AM
Need some opinions 4cstr General Ford Truck and Excursion 8 05-13-2007 05:22 AM
