ecm? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by customdeluxe78, this thread has received 2 replies and been viewed 1129 times.
post #1 of 3 (permalink) Old 01-09-2013, 12:12 AM Thread Starter
99 cummins
customdeluxe78's Avatar
ecm?
ok so today i started the truck up n it lit right up as usual, however it only idled for a few seconds n shut down. I had about 15 psi fuel pressure so i tried again with the same result. At the same time my headlights started flashing, no parking lights, just headlights. The check engine light hasnt been on and ran fine the last time i drove it.
Any ideas? I have a feeling the ecm crapped out but not sure. Any help would be appreciated.
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
post #2 of 3 (permalink) Old 01-09-2013, 09:39 PM Thread Starter
99 cummins
I've found that something is trying to ground out thru the security relay. Now i just have to find the bad ground
post #3 of 3 (permalink) Old 01-13-2013, 11:01 AM Thread Starter
99 cummins
so it wasn't a bad ground. somehow the security system was activated, i have no idea how. that is what caused the lights to flash and truck not to start. i simply locked and unlocked the doors with the key pad and the lights went off and it fired right up n ran good!
Anyway, thanks for all the help, couldn't have figured it out without you all.
Oh well, maybe somebody will read this n have the same problem i guess n know what to do
