First time rebuilding a diesel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by twenglish1, this thread has received 3 replies and been viewed 1208 times.
post #1 of 4 (permalink) Old 05-28-2013, 02:43 AM Thread Starter
Newbie here, I recently picked up a 24 valve Cummins 5.9l complete, only missing injection pump, in need of a rebuild (melted piston) and I have some questions:
First what is the best way to remove melted aluminum from a cylinder wall? I want to avoid over boring if possible
And my last question for now, how did pieces of melted piston rings end up in adjacent cylinders? This seems really weird this would happen, for me, but it deffinitely happened while the engine was running (pieces embedded in pistons)
Thanks in advance
twenglish1 is offline
post #2 of 4 (permalink) Old 05-28-2013, 03:36 AM
You can sleave the bad cylinder. Last one we did was about 300 to get it done. Then just get a new stock piston.
As for the extra parts in another cylinder? good Question. I don't have a clue but it does happen.
later is offline
post #3 of 4 (permalink) Old 05-28-2013, 11:05 PM Thread Starter
Well i used a ridge reemer to remove heavy aluminum build up from the cylinder walls, it worked good, then i ran a drill hone through the cylinder to try to remove the scratches, i'm trying to avoid boring, but i'm not sure that is possible, whats a good rule of thumb to go by when determining whether i need to bore the cylinder? The scratches are vertical in the cylinder, not too deep, but the hone wont remove them
post #4 of 4 (permalink) Old 06-04-2013, 01:08 PM
Your call, vertical scratches will cause the engine to burn oil. You might get by with cast iron rings but they won't last more than 40 or 50,000. If you have gone to all this work why not just go ahead and fit it right and have a sleeve installed. With a sleeve you can just install one new piston and go back stock. Stock Cummins pistons are about 100 dollars each, so if you bore the block out to the first over size and install a complete set of new pistons, that will cost more than a sleeve.
later is offline
Tags
melted piston, newbie question, rebuilding
First time diesel raylanr 2003-2007 6.0L Power Stroke 6 05-02-2012 12:15 AM
first time with a diesel what do I need deezerider 6.5L Diesel Engine 1 01-24-2008 11:42 AM
Always GM, First time Diesel HDbajakid Duramax 07.5-2010 (LMM) 7 09-04-2007 03:17 PM
1'st time posting? 1'st time dodge diesel owner trikes 5.9L Cummins 12 Valve (1994-1998.5) 18 07-22-2007 01:24 PM
Long time Diesel driver, first time poster FireHunter Introductions 11 12-05-2006 07:00 PM
