Quiet her big *** down! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gunner1968, this thread has received 6 replies and been viewed 1807 times.
post #1 of 7 (permalink) Old 05-29-2013, 11:10 PM Thread Starter
Gunner1968
Have been looking and reading what i could find on how to quiet my truck down. (1999 Dodge 4x4/3500/extcab/laramie/5.9turbo diesel/ dually...
acetone/ synthetic 2stroke oil/ hpx-mod?Is there not a part just for a dodge. She has the magnaflux exhaust. acetone and the 2 stroke oil sound like they might truly help, but.. there has to be something more permanent.... Any help would be greatly appreciated.
gunner1968 is offline
post #2 of 7 (permalink) Old 05-30-2013, 05:43 PM
BUCK2's Avatar
It is just the nature of that motor, I ran 2 cylce oil in my 95 and it made a noticeable difference in it.
Give that a shot, I used 1/2 ounce per gallon some use 1 ounce, Im would try one tank with a 1/2 per gallon when you fill it up and add a little to the fuel that is still in the tank, then it easier to keep track of. What i did was buy 2 smaller bottles I thik they were 10 or 12 ounce bottles and I kept a gallon of it in my tool box and I just refilled the small bottle when needed.
I used Walmart brand make sure it is the 2wc3, i think it was Super Tech made for walmart.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #3 of 7 (permalink) Old 06-11-2013, 12:29 PM
Common Rails are much quieter partly because they run more insulation on the engine. The air induction (air cleaner assembly) will make a difference in the engine noise, and the exhaust. After that pull the interior out and and start adding sound deadening.
later is offline
post #4 of 7 (permalink) Old 06-25-2013, 06:08 AM
I guess i could give it a try as well.
Agrippasmith is offline
post #5 of 7 (permalink) Old 06-29-2013, 11:38 PM
Did I say you can tighten up the valve lash just a little and reduce the valve train noise. Try setting the lash at 12 thousands on the intake and 14 thousands on the exhaust. If you want to pickup a little performance set them at 10 thousands both sides, but I feel that may be just a little tight. Stock is 20 thousands both sides.
later is offline
post #6 of 7 (permalink) Old 07-04-2013, 03:30 PM
bmoeller's Avatar
If you wanted quiet, why didn't you buy a 3rd/4th gen, or a Dmax?
The Common Rail Cummins engines aren't quieter from more insulation. It is because of the multiple fuel injection events, vs one big single shot of fuel. Some engines have up to 5-7 injection events per. Mostly done to meet emissions.
One of the reasons the ISB is so loud, is because of the more advanced pump timing, which is computer controlled.
"Obama = Hoax and Chains"
bmoeller is offline
petek (07-04-2013)
post #7 of 7 (permalink) Old 07-04-2013, 09:49 PM
Good point but my 6.7 does have more insulation than my ISB. And that has to have some effect.
later is offline
LOVE HOW QUIET HAS BEEN IN HERE!!! quick83 2008-2010 6.4L Power Stroke 6 04-02-2013 11:44 PM
The quiet generator charlie g The Parking Lot 0 10-09-2011 02:22 PM
Quiet cab. Taco XL 1994-2003 7.3L Power Stroke 14 05-03-2008 03:16 AM
Quiet Exhaust Redrockit 2003-2007 6.0 Tuner Forum 9 01-16-2007 03:31 AM
Quiet Stacks crzycowboy Supporting Vendors Forum 11 11-14-2006 11:02 AM
