2001 dodge Overheating when pulling trailer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RachelJeanWalker, this thread has received 4 replies and been viewed 2577 times.
post #1 of 5 (permalink) Old 06-07-2014, 03:54 PM Thread Starter
I recently bought a 2001 dodge ram 3500. The truck run great but but when you are pulling a trailer the truck according to the gauge wants to overheat. Today I am adding a mechanical gauge, I replaced the clutch fan and thermostat. Any other suggestions would be greatly appreciated. I dont want to waist time rotting radiator I would just like to replace with bigger one when looking into the radiator it looks clean but also can see all the way to bottom. The gauge runs between 200 and suddenly will go to 240. Thanks for your help....
RachelJeanWalker is offline
post #2 of 5 (permalink) Old 06-08-2014, 08:47 PM
Be sure your radiator cap is holding the proper preasure and the antifreeze is around -40F, the fluid is clean, you can wash out the radiator exterior, with a presure washer being sure the fluid goes straight in, many units will collect junk between the cores, causing restricted air flow, bug carcases stuck in the core. You might want to take the rad to a rad shop they can clean it inside and out and test it, CAC as well.
Look at the overflow/surge tank it has a hose on it, if the hose is wet at the end it you may want to do a bottle test on it.
Just a thought!
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
RachelJeanWalker (06-09-2014)
post #3 of 5 (permalink) Old 06-20-2014, 04:44 AM
ADMIN/MAFIA
neeltburn's Avatar
Bottle test it... See if she blows bubbles...
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 5 (permalink) Old 06-20-2014, 03:20 PM
BUCK2's Avatar
I had the same problem on my old 95 model, come to find out the radiator had so much calcium build up in it that i had to replace the redaitor and it fixed the problem.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #5 of 5 (permalink) Old 06-22-2014, 01:32 AM Thread Starter
Sorry I had forgot that I had posted this I also found the radiator needed to be replaced problem solved -----I thank everyone for the posts
pulling an air brake trailer with my truck, I need the hook up dondiesel444 Medium and Heavy Duty 24 07-31-2013 07:01 PM
Dash shakes/vibrates when pulling trailer honda_guy4 2008-2010 Body & Suspension 5 05-03-2010 12:08 AM
Pulling a 5th Wheel Travel Trailer Question UT CUMMINGS 5.9L Cummins (2003-2007.5) 14 04-19-2008 03:04 AM
Manual Tranny temp pulling travel trailer GOPDiesel 2003-2007 6.0L Power Stroke 7 03-24-2008 08:09 PM
Overheating when pulling? STV 2003-2007 6.0L Power Stroke 16 02-23-2007 02:21 PM
