Searching for gear - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RachelJeanWalker, this thread has received 2 replies and been viewed 1024 times.
post #1 of 3 (permalink) Old 07-13-2014, 06:15 AM Thread Starter
Searching for gear
2001 Dodge Ram 1 ton Automatic ---When driving the truck it is searching or surging between gears I was told to wrap the positive side battery cable in tinfoil I thought it was a joke but what the hell I tried it and it seemed to work for a week or so but now back to searching or wandering between 3rd and 4th or with over drive off searching between 2nd and 3rd. Could use a little better advise than tinfoil.
RachelJeanWalker is offline
post #2 of 3 (permalink) Old 07-28-2014, 02:33 AM Thread Starter
problem solved
for those interested a noise isolator can fix this problem. How ever if Dodge had this problem from the factory they would have added one from the start. So here is what I did I changed all the positive cables from the batteries to the starter and to the alternator reset the apps sensor and now it runs like a champ once more no more voltage drops.
post #3 of 3 (permalink) Old 08-07-2014, 06:02 AM
Check the TPS sensor voltage.
openrange is offline
The Following User Says Thank You to openrange For this addition to TDG:
RachelJeanWalker (08-09-2014)
Searching a VIN. TubingJon Ford Oasis requests 3 02-11-2010 04:05 PM
Searching for a new truck I have a few quick q's though CumminsTorq 6.7L Cummins (2007.5-2011) 10 08-10-2009 01:30 PM
Still searching cetnor851 General GM Truck Forum 4 02-24-2008 05:18 PM
searching for gears benhenry 5.9L Cummins (1998.5-2002) 1 06-11-2007 05:50 PM
Overdrive searching Featherman 6.2L Diesel Engine 2 01-28-2007 02:15 AM
