2002 cummins oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rampower, this thread has received 2 replies and been viewed 1124 times.
post #1 of 3 (permalink) Old 09-04-2014, 01:29 AM Thread Starter
well guys I went to look at a truck today, 02 quad cab long bed, only 122k. new injection pump and upgraded fuel pump, after looking over the out side of the truck I popped the hood and saw oil spray on the coolant over flow tank, I asked the guy where the oil was coming from, he said that its was coming from the blow by tube and being sprayed on the tank from the fan, he had said that it was a common problem with the 5.9's and that the tube was made too short.
has anyone else heard of this, and is there a pretty easy fix for it?
rampower is offline
post #2 of 3 (permalink) Old 09-04-2014, 03:43 AM
ADMIN/MAFIA
neeltburn's Avatar
How much blow by does the truck have?
https://www.youtube.com/watch?v=PvDvcl29ZqM
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 3 (permalink) Old 09-04-2014, 07:36 PM Thread Starter
Almost none at all. I wassent able to get a good look down at the motor to see where else the oil may have been coming from. I'm thinking the front cover may have a small leak from when the pump was done and the fans blowing it from there
rampower is offline
8.3 Cummins Oil leak front seal burningoil Medium and Heavy Duty 4 05-27-2011 02:18 AM
Small cam cummins oil leak cdwood388 Medium and Heavy Duty 11 02-21-2011 03:28 AM
OK fuel leak stopped now oil leak Stacked6600 1994-2003 7.3L Power Stroke 7 01-27-2011 03:37 AM
2002 Dodge 3500 A/C Drain Line Leak txcattlejock 5.9L Cummins (1998.5-2002) 5 10-14-2009 08:11 PM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
