gray smoke and wont start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chevyboy3672, this thread has received 0 replies and been viewed 697 times.
post #1 of 1 (permalink) Old 10-01-2014, 03:26 PM Thread Starter
hi i have a buddy with a 01 24 valve and its started to to dump gray smoke out the exhaust so he went and got a new vp44 from O'Reillys it was a BWD and it still did the same thing so he take it back and swapped for another one and still the same issue and we found out that there have a issue with the pumps from BWD so he ordered one form thorough bread diesel i Believe its one thats been turned up but its still having the same problem with less smoke and wont start unless u use alittle ether and only smokes in lower RPMs but cant drive it and he bleed the system and it has a raptor 100 lift any help would be very appreciated
97 2500ext cab long bed. 62 silverbullet ,90hp injector's ,150airdog ,rackplug ,double feed line for injectorpump ,0fuel plate slide up ,ddp dv's ,bd diesel intercooler ,afc mod ,big k&n airfilter , 4" exaust to 8" stack,colt stage 3/big stick cam ,around 14" lift w/t 40's, autometer gauges boost/egt/tranny temp/fp etc............................................... .................................................. .............
chevyboy3672 is offline
Gray Smoke? Johntx73 7.3L and 6.9 IDI (Pre 1994) 5 08-27-2014 03:08 AM
Gray Smoke brut69 Duramax 2001-2004 (LB7) 4 12-24-2007 04:37 AM
Gray smoke coposrv 2003-2007 6.0L Power Stroke 7 03-29-2007 02:15 PM
Blue-Gray smoke on start up? bigs rig 1994-2003 7.3L Power Stroke 8 01-25-2006 01:03 AM
A little bit of gray smoke Fantom3993 1994-2003 7.3L Power Stroke 2 12-24-2005 10:39 PM
