what is the most realistic tuner for a 99 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hayjayhorses, this thread has received 3 replies and been viewed 1399 times.
post #1 of 4 (permalink) Old 11-19-2014, 06:48 AM Thread Starter
hayjayhorses's Avatar
I have a 99 24 valve, it feels gutless, it has a reman injector pump and an aftermaket lift pump. The fuel pressure stays above 20 psi under full throttle. I don't have a boost or egg gauge yet. Has a muffler delet. The tranny is built. Everything else is stock.
Like 50 to 75 horse would be good. I also haul heavy a lot
What do you guys recommend?
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #2 of 4 (permalink) Old 11-21-2014, 12:43 AM
Most of the tuners out there are good.
If I recall correctly that is a 215 HP engine. A tuner is a great place to start. A stock ISB pump only likes 300 to 325 RWHP. RV275 injectors should give you about 40-45 more hp. Or you could change your injector nozzles but if you go larger than 75 hp nozzles you will see smoke and higher egt'.
If I just wanted a little more performance, I would get gauges, 4inch exhaust, 40 or 75 hp nozzles, and a edge comp box. That should be a start.
later is offline
The Following User Says Thank You to later For this addition to TDG:
hayjayhorses (05-23-2015)
post #3 of 4 (permalink) Old 03-30-2015, 11:26 PM
Edge comp or edge EZ and RV275's are an awesome mild street/towing set up. The best mileage I ever got was that combo with the Drag comp box.
The Following User Says Thank You to sstockton For this addition to TDG:
post #4 of 4 (permalink) Old 04-30-2015, 03:12 AM
Hi Jay!
The first thing I did to my '99 was to add a Van Aaken timing module. The gent I bought it from dyno'd before and after installation and saw an honest 70 horse increase.
It really woke up my rig!
Mike
'99 Ram quad cab dually long bed auto, early Van Aaken, Pacbrake, BHAF, Mach 1.5's, TST PMII, mystery switch, Magnaflow 4" system, Lite rider tonneu, home made 2 low kit, Reese 20k fiver hitch, etc...
FORCE 5.9 is offline
The Following User Says Thank You to FORCE 5.9 For this addition to TDG:
SCT 9625 OR tuner '08 0r '09 6.4l Delete tuner $450 shipped! 4613 Whats Been Sold 1 01-02-2010 12:08 AM
DP Tuner dieselsmoke0204 Supporting Vendors Forum 2 06-06-2009 04:45 PM
turning the SCT SF tuner into a custom tuner strokin6L 2003-2007 6.0 Tuner Forum 4 05-26-2009 03:05 PM
ATS E Tuner vs. DP Tuner?? Akstroker 1994-2003 7.3L Chips & Tuners Forum 14 10-31-2007 06:33 PM
Realistic hp and torque numbers from a 05` ctd BogginF350 5.9L Cummins (2003-2007.5) 5 05-13-2006 07:42 PM
