53 block - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bad_cummins, this thread has received 5 replies and been viewed 726 times.
post #1 of 6 (permalink) Old 09-14-2006, 12:15 AM Thread Starter
53 block
How do you determine if you have a 53 block. Is there an identification tag on the block, or any other way of determining it. Thanks for your help guys.
01 Qc Cummins 4x4 long box, edge attitude with juice (HOT!!), 4" exhaust, afe stage 2 intake, HTB2 62/12, banks intake pleum, bully dog big fuel kit, stage three jammers, southbend 3250 DD, BD Blow off valve. PDR master and slave cylinder upgrade. Sold
2006 mega cab 4x4 auto. Stock for now.
bad_cummins is offline
post #2 of 6 (permalink) Old 09-14-2006, 12:30 AM
on the side of the block there will be a big 53 cast into it, look from underneith
DBogo is offline
post #3 of 6 (permalink) Old 09-14-2006, 01:51 AM Thread Starter
Which side? Driver or passenger?
post #4 of 6 (permalink) Old 09-14-2006, 02:03 AM
Bouncer
Driver
post #5 of 6 (permalink) Old 09-14-2006, 05:34 AM
most of the time it is on the driver's side just bellow the injection pump. The numbers are cast onto the block and are about 1 inch tall. They aren't the little guys in a long string, it will just be the two of them.
They are also extremely rare to find in an 01, and they stopped using the block in 01.5, if you have rear disc brakes, you won't have a 53 block. in an 01 you should have a 55 or 56 block, or if you're lucky you have the mexican block.
Also, just to add this in, I have heard of people finding the block code in other places on the engine, but it really isn't that common. And the cracking block isn't a terribly common problem either. I heard a figure somewhere that fewer than 1 in 100 53 blocks crack. However, I can't back that up.
Good Luck,
post #6 of 6 (permalink) Old 09-14-2006, 11:58 AM
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
:iagree
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
