Boost? with edge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JayRock, this thread has received 36 replies and been viewed 1802 times.
post #1 of 37 (permalink) Old 05-30-2007, 01:42 AM Thread Starter
Boost? with edge
i was just wondering what kind of boost levels you guys were seein with your edge juice boxes. I drive mostly on level 2 and I see 18 psi max and 21 on level five. It seems low to me thats why im askin.
JayRock is offline
post #2 of 37 (permalink) Old 05-30-2007, 03:12 AM
mine is do in the same but worse. on 5x5 it only gets to 17psi, stock they get to 20-21psi
RED DRAGON is offline
post #3 of 37 (permalink) Old 05-30-2007, 03:23 AM
tbroadus_41's Avatar
I've seen mine as high as 23, but i don't recall what setting it was on. I''l watch it tommorrow and get back.
tbroadus_41 is offline
post #4 of 37 (permalink) Old 05-30-2007, 01:27 PM
i've gotten mine up to about 27 but thats the highest
bada$$dodge2000 is offline
post #5 of 37 (permalink) Old 05-30-2007, 03:00 PM
well if you still got your waste gate functional ur not goin to see that much. i get 28 psi with a bully dog j hoook on mine.
Josh
01 2500 dodge 24 valve 200k miles, striaght pipe exhaust, bully dog j-hook,home made cold air intake,Full Georend tranny,billet input,billet output,lam flex plate, TQ lock-up switch, Holley Blue pump, RV275's, BD top speed elimintator w/RAD Hot Edge juice w/Attitude
:smoke
masonjo is offline
post #6 of 37 (permalink) Old 05-30-2007, 03:31 PM Thread Starter
When I got the truck it had all banks crap on it and it would read around 36 psi. I hate banks and thinks that his box was a joke so I immediately took everything off.
I do have the j-hook though, Is that a pain to put on?
JayRock is offline
post #7 of 37 (permalink) Old 05-30-2007, 04:40 PM
TDG Mafia Member #45
jarhead's Avatar
I get 32 with an edge ez on the low setting.
Randy
05 Dodge str8 pipe, smarty jr, afe, airbags, and pacbrake.
jarhead is offline
post #8 of 37 (permalink) Old 05-30-2007, 08:48 PM
Cool
sounds like ya'll need a turbo or go find the little boost elbow for a hx35x like you guys have!!! you will have to do some drillin if im not mistaken cause there is no way to get in to the vacum side of the wastegate or u could just put another turbo on!!!! like a hx40x or hx35x i put a 35 on from my old turd and im gettin 31psi in the intake with stock wastegate :smoke
REDNEK0195 is offline
post #9 of 37 (permalink) Old 05-30-2007, 11:32 PM
01-02 auto's have the hy-35
post #10 of 37 (permalink) Old 05-31-2007, 01:39 AM Thread Starter
Well I guess it sounds like mine is in the norm. I was just curios because when I had the Banks Ottomind the wastegate would huff like a bad*****. I couldnt believe that it was making 36 pounds, but maybe it was. I'm gonna put the j-hook on tomarrow night and see what happens. Other then that how much can I get out of an HY?
JayRock is offline
