Edge Comp box swap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smokem, this thread has received 6 replies and been viewed 873 times.
post #1 of 7 (permalink) Old 06-01-2007, 09:59 PM Thread Starter
Edge Comp box swap
Can my 98 Edge Comp box be swapped to a 02?
Are the plug in's different? or can they be wired up or interfaced if not. Or did mine come with a adapter that I might have thrown away?
Smokem is offline
post #2 of 7 (permalink) Old 06-02-2007, 04:28 AM
The box should work on your 02. The only difference is the MAP sensor plug. I believe Edge makes an adaptor for that. Hell, my Banks PowerPack Ottomind is from a 01 and my truck is a 02. All's I did is change the MAP sensor plug. Works like a charm....................
JPR Ram is offline
post #3 of 7 (permalink) Old 06-02-2007, 06:48 AM
If you're already wired up and just switching the boxes, then yes it will work. The wiring harness they send is different because the map sensor has a different plug.
post #4 of 7 (permalink) Old 06-02-2007, 09:31 PM Thread Starter
Good as long as the box's are the same thing I'll be good.
Smokem is offline
post #5 of 7 (permalink) Old 06-03-2007, 04:40 AM
Cummins Man
Dazedandconfused's Avatar
Ok I could be wrong but I thought the 98.5 to 00 boxes were programmed different. The 01 and 02 boxes were the same other then Map sensors. I'm almost postive this is what Edge told me.
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #6 of 7 (permalink) Old 06-03-2007, 04:55 AM
D_B
He is right! :Thumbup:
DB
1999 Dodge Ram 2500 LWB, Intense Blue, 5spd,
4:10's, all kinds of goodies and doodads!
NRA Lifer
D_B is offline
post #7 of 7 (permalink) Old 06-03-2007, 02:12 PM Thread Starter
K, I'll keep this in mind then.
Smokem is offline
