bad connection - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RED DRAGON, this thread has received 2 replies and been viewed 511 times.
post #1 of 3 (permalink) Old 06-03-2007, 04:20 AM Thread Starter
bad connection
the lights in my juice module say that the wire isnt tapped correctly becuase they arent scrolling. i have tried to fix this a few times before and it did work for a while but it goes back to acting light it is in ez mode and the pump isnt tapped. so is there a better way to make a connection with the pump wire? is one of them pump covers worth a try?? an suggestions are a huge help thanks in advance!!
RED DRAGON is offline
post #2 of 3 (permalink) Old 06-03-2007, 04:29 AM
D_B
Pump cover may help but if it where me I would do like I did on my pump and tap.
I just took and stripped the wire back about an inch or so and soldered in a tap (short peace of wire) with a waterproof connector on it. I used some good heat shrink tubing to cover up the bare wires for added waterproofing. Now I just plug and unplug my Juice or any other box from the pump wire. I started doing this with my TST box long ago when it gave me problems with loose connections. Works great and you won't have another problem out of it. :Thumbup:
DB
1999 Dodge Ram 2500 LWB, Intense Blue, 5spd,
4:10's, all kinds of goodies and doodads!
NRA Lifer
D_B is offline
post #3 of 3 (permalink) Old 06-05-2007, 01:26 PM
Boost Junkie
soldering and heat shrink is the best way to have a problem free connection for sure. I agree with DB. I didn't want to tap my pump wire but i think i will just tap into it with put a spade connector on the end so you can plug and up-plug boxes as needed.
Josh
91rangerturbo is offline
