Dead Pedal and Popping when Reved - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminspride, this thread has received 9 replies and been viewed 777 times.
post #1 of 10 (permalink) Old 06-03-2007, 11:59 PM Thread Starter
T.D.G. Mafia Member #88
cumminspride's Avatar
My buddy has 01 2500 5spd 4x4 w/edge juice and had daves diesel replace the vp (upon failure of course and lift pump after market i do not know:shrug with a hot rod pump brand i do not know. after 40 or 50k now he's getting dead pedal and a pop or a miss when its reved. hes replaced the map sensor and now the apps. no change its throwing pps codes still. Where do we go from here? He needs help with this, its his daily driver 140 miles a day.:thanks:
cumminspride is offline
post #2 of 10 (permalink) Old 06-04-2007, 12:05 AM
D_B
What codes is it showing?
Sounds a lot like another dead VP or some issues with the connection of the pump tap on the Edge box.
The codes will help us figure out what's up but you could also take off the Edge box and see if the problem is still there.
DB
1999 Dodge Ram 2500 LWB, Intense Blue, 5spd,
4:10's, all kinds of goodies and doodads!
NRA Lifer
D_B is offline
post #3 of 10 (permalink) Old 06-05-2007, 03:07 PM Thread Starter
Not sure on the exact code but it was a apps sensor code so he replaced it and the prob is still there. and also he did unhook the juice and the problem is still there.:shrug:
post #4 of 10 (permalink) Old 06-05-2007, 11:07 PM
I'll bet that's the right answer. Unless your 100% positive you got a APPS code.
A dead VP44 will almost always pop and/or miss when reved. Dump some Marvel in there, sorry if I sound like a spokes person for Marvel, that's all that works in my truck.
Smokem is offline
post #5 of 10 (permalink) Old 06-06-2007, 11:57 AM Thread Starter
He's gonna try the marvel:Thumbup:
post #6 of 10 (permalink) Old 06-06-2007, 12:02 PM Thread Starter
Also do any of you feel like the ULSD is lubricated and or the additives that are supposed to be added for lubricity maybe don't get added due to the market and profit margin of fuel these days?
post #7 of 10 (permalink) Old 06-06-2007, 10:39 PM
They probably add something but it's probably not much. My truck had problems before ULSD. So I don't know. But Marvel has been like trial and error for me. I've tried every, and I mean EVERY fuel additive out there. The only one to work for me has been Marvel, which is wierd because it is also one of the cheapest, and easiest found.
I'm about ready to start rebottling it up jacking up the price by 3 and calling it something else, not really. But about other people do that.
Smokem is offline
post #8 of 10 (permalink) Old 06-06-2007, 10:55 PM
Cummins Man
Dazedandconfused's Avatar
I would say it is the VP, the diafram is probably damaged. Usually it wont allow the timing to change causeing the poping.
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #9 of 10 (permalink) Old 06-07-2007, 08:59 PM
When my truck does the dead pedal it just acts like a dead pedal. So if all it's doing is losing timing, wouldn't I be blowing out black smoke (which I'm not) I don't know, I'm bunting ideas.
Smokem is offline
post #10 of 10 (permalink) Old 06-07-2007, 09:16 PM
Cummins Man
The popping is due to timing not advancing. The dead pedal is the electronics failing.
Andy
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
