Any help with codes guys? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by veritas42, this thread has received 5 replies and been viewed 525 times.
post #1 of 6 (permalink) Old 06-04-2007, 09:16 PM Thread Starter
The other day out of curiosity I turned my key 3 times and checked my codes. I got 0500 and 1693 I went to AZ and they were something about the tach and the speed sensor or something. Anybody ever had these codes? Also if you have are they A big deal? Or is it just something minor I should replace? OR what any comments/ help appreciated
veritas42 is offline
post #2 of 6 (permalink) Old 06-04-2007, 09:24 PM
Never Listen to a Monkey!
Send a message via AIM to CBRJohn2000 Send a message via MSN to CBRJohn2000 Send a message via Yahoo to CBRJohn2000
It would probably be helpful if you could post your truck information; Make, Model, Engine and Mods if any would make answering your question MUCH easier.
John
2005 Dark Blue Metalic 2500HD LT CC/LB 2wd w Dual Alternators, RSEC, 06 Towing Mirrors, Snug Top Bed Cover,Edge Juice/Attitude, F/S, B/P, B/S, TxC CAI, TxC V2 w/fan, Mike L. Trans. Cooler, Suncoast 6spd Conversion Kit, Factory Style Lighted Running Boards, Tekonsha Sentinel 9055 Brake Controller. Michelin 265/75r16 LTX M/S tires. ......... Born On 02/05
2001 Saturn L200 (Wifes Daily Driver)
1977 Ideal Travel Trailer 7K+
1978 Wreidt Boat w/Berkley Jet SB 350
CBRJohn2000 is offline
post #3 of 6 (permalink) Old 06-04-2007, 10:23 PM
No real worries there. P0500 is no vehical speed sensor signal, and P1693 is a companion code Detected Trouble Code DTC in either ECM or PCM. Do you have an anti defueler or top speed eliminator? Those will throw those codes for sure. If not, then you probably had a little slip up in communication between the ECM and PCM also could be caused by an old and tired VSS or something in that system.
post #4 of 6 (permalink) Old 06-04-2007, 10:45 PM
tbroadus_41's Avatar
Also if you'll notice at the top of the forum page there is a sticky with the codes posted right there for you.:smoke
tbroadus_41 is offline
post #5 of 6 (permalink) Old 06-04-2007, 11:03 PM Thread Starter
Ok thank you for the reply guys? Oh ya sorry 01 ctd 47re auto straight stock.
fass fuel system on the way. already had some fun with the lift pump. Also stockton is there anything I should replace with those codes gettting thrown?
Oh ya I did spray down the engine the other day would that maybe throw the codes?
post #6 of 6 (permalink) Old 06-04-2007, 11:11 PM
I wouldn't rush out and replace stuff. I would try clearing them and see if they come back, If you keep having issues, I would see if you can get your speed sensor tested. My friends truck used to eat output speed sensors for some reason, Well, it ate 2 in maybe 18 months anyways it could be something like that, they only cost about 25 bucks so they aren't too expensive. He would have shifting issues though, like 1st and 3rd would just go away. So I don't think you have anything to worry about.
