ABS/E-Brake light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Fanatic, this thread has received 7 replies and been viewed 568 times.
post #1 of 8 (permalink) Old 06-04-2007, 10:34 PM Thread Starter
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
ABS/E-Brake light
I am getting an ABS light along with the E brake light, and my cruise won't work. I changed the VSS in the trans, and the ABS sensor in the rear end, and I am still getting an occasional problem with it. What might the problem be? I have done everything I could think of.
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #2 of 8 (permalink) Old 06-04-2007, 11:13 PM
Well, it could be the ABS control module, but I don't think that that would effect the cruise control. Is it always flashing or just ocassionally.
post #3 of 8 (permalink) Old 06-04-2007, 11:15 PM Thread Starter
TDG Mafia 36
Both lights stay on solid
post #4 of 8 (permalink) Old 06-05-2007, 01:19 AM
Bouncer
The tone ring in the rear end could have multiple teeth broken on it. This can cause both problems. Does your speedo jump around at all?
post #5 of 8 (permalink) Old 06-05-2007, 01:19 AM
I'd have your abs module checked.
post #6 of 8 (permalink) Old 06-05-2007, 01:53 AM Thread Starter
TDG Mafia 36
It did until I changed out the sensor on the rear diff, I haven't noticed it since then, but it would jump 10-15 mph before I changed it.
post #7 of 8 (permalink) Old 06-05-2007, 02:30 AM
Bouncer
Have you unhooked your batteries and tried to reset it?
post #8 of 8 (permalink) Old 06-05-2007, 01:58 PM Thread Starter
TDG Mafia 36
Not yet, I will try that today, while I am doing nothing. I hate not having money to play with...
