Best ATF - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bada$$dodge2000, this thread has received 14 replies and been viewed 1090 times.
post #1 of 15 (permalink) Old 06-06-2007, 01:38 PM Thread Starter
Best ATF
what do you guys use for ATF in your gas tanks?? what one is the best one??
bada$$dodge2000 is offline
post #2 of 15 (permalink) Old 06-06-2007, 02:09 PM
Dad
ATF? Automatic Transmission Fluid? I think most people will warn you off adding ATF with the VP44 due to the friction modifiers in ATF which in effect result in less lubricity.
Most are adding 2-cycle oil at 128:1 ratio to increase lubricity of the fuel.
Dad is offline
post #3 of 15 (permalink) Old 06-06-2007, 02:15 PM
4cstr
I'm not sure about adding ATF either. The fact that its red...and would most likely add a red tint to your fuel...would make it very difficult to explain to Mr. DOT that you aren't running untaxed fuel...but added ATF.
post #4 of 15 (permalink) Old 06-06-2007, 02:29 PM
does 2-cycle oil help any thing in performance or engine life?
redneckchief is offline
post #5 of 15 (permalink) Old 06-06-2007, 02:31 PM
Boost Junkie
128:1 ratio is that to a full tank of fuel? I am curious about this is there more reading on this somewhere?
Josh
91rangerturbo is offline
post #6 of 15 (permalink) Old 06-06-2007, 03:01 PM Thread Starter
no guys im talking about fuel additives
post #7 of 15 (permalink) Old 06-06-2007, 03:23 PM
Boost Junkie
ATF stands for automatic transmission fluid.. Could you please be a little more descriptive?
Are you asking if you can put ATF fluid in your fuel tank?
Josh
post #8 of 15 (permalink) Old 06-06-2007, 07:49 PM Thread Starter
ya i have heard that you can mix it with fuel in your tank
post #9 of 15 (permalink) Old 06-06-2007, 10:36 PM
He is right, treating your fuel with ATF will kill a VP44 in about 20-30k miles. Use Marvel, it's the best, I've tried everything with Marvel being the holy grail of fuel additives.
Smokem is offline
post #10 of 15 (permalink) Old 06-07-2007, 02:28 AM
what does the marvel do for diesels?
