2001 buy or not - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cold fodged, this thread has received 10 replies and been viewed 886 times.
post #1 of 11 (permalink) Old 06-06-2007, 09:06 PM Thread Starter
2001 buy or not
Hi this is my first post here. I have been reading and looking at everyones posts for a while now as a guest and now i need some advice. I found a 2001 dodge regular cab with a 6speed it is of couse the lengendary 5.9 Cummings. the truck looks like its in mint condition. i can afford to buy it but when i do cant afford to fix anything on it for at least a year(it will take me that long to save anything that might put a dent in parts for it, i can do repairs myself which is good). the truck only has 85k on it. an older man about 55 owned it. he never pulled alot with it just his camper and boat. I pretty sure its never been chiped or had a power program on it. Its all stock.
Do you all think it will give me a couple years of trouble free service.:thanks:
Cold fodged is offline
post #2 of 11 (permalink) Old 06-06-2007, 09:14 PM
Cummins Man
Dazedandconfused's Avatar
Welcome to TDG!!!
Well i have an 01 and have never really had any problems other then a slipping auto. Take a look at the truck, check for codes and report them back. To do the key trick turn it on/off/on/off/on without starting the truck and watch the odometer window. It will bring up codes if there are any. I would have fuel preasure checked and at least replace the lift pump if it is below 10psi at idle. Other then that just look for leaks, or any wierd noises. You should have to problems with it. Is it a 4x4 or 4x2 truck?
Andy
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #3 of 11 (permalink) Old 06-06-2007, 10:43 PM
If you have a 2wd you'll be fine, on top of getting almost 30 MPG on the highway. Make sure to keep an eye on your fuel pressure and maintence and you'll be fine.
Smokem is offline
post #4 of 11 (permalink) Old 06-06-2007, 11:07 PM Thread Starter
4x4
4X4. i alredy checked it for codes every thing was ok. i havent jacked up the front end to check ball joints but with 85k on it and never really towing a heavy load much i think it should be ok.
post #5 of 11 (permalink) Old 06-07-2007, 12:30 AM
I loved mine, and after relocating to lift pump back by the tank, I never had a fuel pressure problem. Mine had 180k on it when I got the death code(s) for the injection pump. never had any tranny problems, even with the Edge EZ hooked up. You should be fine, just install a fuel pressure gauge.
I have the gauge pod, tow mirrors, and the Edge ez for sale on this site under the Dodge parts store.
03 3500HD 6x6 starting the add ons.
HAD'01 Ram 2500 SLT Laramie 4x1of2, 24v CTD, electric blue on silver 2-tone, matching blue spray-in bed liner, leveling spacers in front end, 3:55's, 'pork chop' tool boxes and tailgate box, back up/ work lights under rear bumper, On-board air, Roof mounted Air horns, Gauges in Pillar include Fuel PSI (pre & post filter), Oil PSI, Boost/EGT, Engine temp/Trans temp. BHAF, Edge EZ
Firestorm is offline
post #6 of 11 (permalink) Old 06-07-2007, 01:56 AM
tbroadus_41's Avatar
Make sure the six speed is what you want. mine is the five speed and my roomate owns a truck like what you have described after driving both of them i would not trade him for anything unless all i did was pull, the gears are just to close for me.
tbroadus_41 is offline
post #7 of 11 (permalink) Old 06-07-2007, 02:32 AM
i love my 6 spd but my cousins 06 ctd 6spd shifts way better more crisp or something like that
redneckchief is offline
post #8 of 11 (permalink) Old 06-08-2007, 12:29 AM Thread Starter
They Cut me such a deal couldnt pass it up. the ball joints were replace do to recall at 33000 and the lift pump was replace at 55000. figured that was the biggest concern so nowing this made me feel alot better. thanx guys for all the help. i got one more big question 4 ya ill start a new thread for that
post #9 of 11 (permalink) Old 06-08-2007, 03:13 AM
haz-mat19's Avatar
The track bars aren't too strong either had mine done at 45k and I am about do again, just a heads up. Like they all said, as long as you f/p is good you will be in good shape.
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #10 of 11 (permalink) Old 06-08-2007, 04:45 PM
What more can be said? I love mine.
My company has some of the newer trucks from dodge 2006 and 2007 too quiet. I think if you buy the truck you will love it the only Major problems have been talked about in the above posts. 1.I forget the block casting number but one was prone to cracking at the block. I think it was the "53" block but don't quote me on that. 2. lift pump problems easy to mod and fix. 3. Keep the vp44pump well lubed and the fuel pressure above 7 psi and you should have no problems( I like a higher fuel pressure but cummins says 7 psi is enough with good flow) 4. some folks complain about the front end. I have had no problems with mine except for normal wear and tear. I like to think it was more a tire problem than anything else. Enjoy your new truck and above all have fun drive the heck out of it and enjoy the big grin on your face.
2001 Dodge quadcab 4x4,Auto transmission,Fass 150/150 pump, Among other upgrades.
todt061458 is offline
