check fuel pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redneckchief, this thread has received 6 replies and been viewed 1039 times.
post #1 of 7 (permalink) Old 06-07-2007, 02:37 AM Thread Starter
check fuel pressure
would it be a good idea to get a fuel pressure gauge my truck has 106,000k
on it and i will eventually get an edge juice w/attitude which i heard has a fuel
pressure gauge and warning light but untill then i'd like to know whats going on under the hood
redneckchief is offline
post #2 of 7 (permalink) Old 06-07-2007, 03:31 AM
tbroadus_41's Avatar
For sure my truck had 120,xxx when i installed my attitude and it was reading 5psi, the attitude saved my butt. i just can't say enough about the juice w/attitude i love it.
tbroadus_41 is offline
post #3 of 7 (permalink) Old 06-07-2007, 02:23 PM Thread Starter
can any one recomend a decent fuel pressure gauge set nup for low cost?
post #4 of 7 (permalink) Old 06-07-2007, 05:13 PM
Boost Junkie
do you want electric or mechanical?
Josh
91rangerturbo is offline
post #5 of 7 (permalink) Old 06-08-2007, 02:24 PM Thread Starter
any thing that is easy to install and will work till i get my edge
post #6 of 7 (permalink) Old 06-09-2007, 05:57 AM
Boost Junkie
You can pickup a Low Fuel Pressure LED that is simple to install for around 50 bucks if that is all your wanting.
Josh
post #7 of 7 (permalink) Old 06-09-2007, 02:18 PM
2nd Gen Guru
Mopar1973Man's Avatar
Here is a write up on my gauges setup and where I got them at...
http://www.frontiernet.net/~mopar197...icol_gages.htm
Mopar1973Man is offline
