Stacking - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tbroadus_41, this thread has received 7 replies and been viewed 982 times.
post #1 of 8 (permalink) Old 06-07-2007, 03:34 AM Thread Starter
tbroadus_41's Avatar
Stacking
What can i stack with what i already have? I know the smarty will work but what else is there and what do you think. I'm not real sure if i want to go with the redline box either.
tbroadus_41 is offline
post #2 of 8 (permalink) Old 06-07-2007, 02:01 PM
smarty is a good because you can go from adding timing to not i have an hypertech stacked onto my edge comp i dont know if the hypertech will work with the juice w/attitude or not but i would go with the smarty thats my next thing after the turbos
xjjeep00 is offline
post #3 of 8 (permalink) Old 06-07-2007, 09:27 PM
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
I also heard that the quadzilla Xzillarader works well with a timing box, was told today that it doesn't advance timing far enough to make a difference when running it with a timing box
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #4 of 8 (permalink) Old 06-09-2007, 02:45 PM
2nd Gen Guru
Mopar1973Man's Avatar
I've tried the Smarty / Edge Comp stacck... It's like OMG! :evil:
The power is so mean that a stock clutch cant hold the horse power of the stack. So if your thinking of this you better think about a few things. Like a modified exhaust housing on your turbo or new turbo, upgraded clutch or tranny, and good fuel supply! :Thumbup:
Mopar1973Man is offline
post #5 of 8 (permalink) Old 06-10-2007, 10:26 AM
Go with the DRAg comp ( EDGE HOT) and the smarty.. Beastly combo.. and the smarty removes the Rev limiter.. so if you have fuel you can keep going and going!:evil:
WBV06CTD is offline
post #6 of 8 (permalink) Old 06-10-2007, 02:32 PM
Banned
Send a message via AIM to lukesdiesel
Smarty= :smoke
lukesdiesel is offline
post #7 of 8 (permalink) Old 06-10-2007, 04:31 PM
2nd Gen Guru
No joking! :gun:
post #8 of 8 (permalink) Old 06-10-2007, 06:02 PM
Stacking the hypertech with the comp or juice can make the engine knock from too much timing. The hypertech increases the timing more than it changes the fuel curves. The smarty is prolly the best stack since it lets you do the fuel or fuel-timing thing. I don't think i have ever heard of stacking the quadzilla with any of the edge products. If it taps the pump wire then it is pointless because the two wire tap signals fight each other.
Stephen!
StrokeThisGoat is offline
