fass - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redneckchief, this thread has received 2 replies and been viewed 740 times.
post #1 of 3 (permalink) Old 06-09-2007, 01:36 AM Thread Starter
fass
does the fass fuel system replace the injection pump on the ctd ?
redneckchief is offline
post #2 of 3 (permalink) Old 06-09-2007, 03:35 AM
no the fass system only acts as a high pressure lft pump that keeps fuel to the injector pump so that it does not run dry and burn up. vp pumps are known to go bad because they are starved for fuel.
MOOSE 04 is offline
post #3 of 3 (permalink) Old 06-09-2007, 02:36 PM
2nd Gen Guru
Mopar1973Man's Avatar
I gather you don't have a fuel pressure gauge either???
http://www.frontiernet.net/~mopar197...icol_gages.htm
Then the minimum pressure require to the VP44 injection pump...
You might want to jump for a Vulcan Big Line kit...
http://www.frontiernet.net/~mopar197...n_big_line.htm
Check out the position of my lift pump and this is the pump I'm currently running...
http://www.frontiernet.net/~mopar197...paign_pump.htm
Mopar1973Man is offline
