Popping noise when I hit the brakes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WBV06CTD, this thread has received 2 replies and been viewed 667 times.
post #1 of 3 (permalink) Old 06-09-2007, 05:38 AM Thread Starter
I hear a popping noise coming from the back of my truck when I hit the brakes... I thought it might be my traction bars but they are secure.. What else could it be? Maybe a u joint or the calipers on the back?
WBV06CTD is offline
post #2 of 3 (permalink) Old 06-09-2007, 07:15 AM
bmoeller's Avatar
Check the spring u-bolts.
Doubt it is a u-joint. You'd probably feel that shaking.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 3 (permalink) Old 06-10-2007, 03:02 AM
calipers
check the caliper mounting bolts if the rear pads have been changed recently the mounting bolts if not properly torqued will back off and when you apply the brake pedal the caliper will rock back and forth causing a clicking or popping noise
longgunner is offline
